Originally posted by Piotrek K Have to buy the trigers or the small slave flash that can omit preflash as I cannot fire any of my non-PTTL flashes via hotshoe;-)
I'd really recommend trying some of the very cheap radio triggers I (and others) mentioned. I bought mine as a very inexpensive (almost "throw away" cheap) way of trying out a manual radio setup for the first time, with the expectation that I'd upgrade to something better if I liked working with them. But I've been so happy that I've not felt the need to upgrade yet.
That said, my own use cases are very simple... primarily product photography and similar at this point, mostly using one, two, or - in very rare circumstances - three flash units. Aside from being able to set up transmit and receive channels and test fire the flash from the trigger, there's no other functionality whatsoever. But I confess, I rather like the simplicity. If you think you'd be OK with that too, these triggers are no brainers for a first or inexpensive step into radio controlled manual flash work
