Originally posted by gcisko The option for Scene->Macro is pretty much useless. It seems I need to check the macro extension rings (I already have the 06 lens). Do I have this right? Thanks much.
Hello welcome to the forum and the Q.
The macro setting never changes the close up abilities of interchangeable lens cameras. Cameras with a built in lens change the actual spacing between glass elements.This allows much closer focusing. The Q, or any other interchangeable lens camera, can't change lens element spacing.
The extension tubes have too much length. Only the shortest tube will work with the 06. You are better off buying close up filters for the front of your Q lenses.
Looking forward to seeing some of your pictures and discussing the Q.
Thanks,
barondla
