02-23-2019, 08:01 AM   #1
johnmflores's Avatar
12V charging options?
I'm planning a bike trip this year and plan on bringing the Q along. I'll probably bring a 12v battery pack. Is there any way to charge the Q batteries with 12v power?
02-23-2019, 08:56 AM   #2
It's not possible to directly charge a 12V battery from 12V power since they have the same electrical "pressure" and won't push charging current into the battery being charged. I'm not familiar with the Q but I assume you're referring to charging a 12V Q pack from vehicular 12V power.
One good solution is to take your regular charger, and purchase a 12V inverter which converts 12V from your 12V source to 110VAC and then plug in your Q charger. These inverters are small and for that purpose (low power) can be had for as little as $10US (Monoprice - AUKEY 150W), plus you have 110VAC for other low power needs should they arise. Some inverters also feature a 5V USB output which comes in handy.
The only other solution is to purchase a special charger which runs off 12V and charges the Q pack (don't know of any source, but they may exist). They basically boost the 12V internally and then regulate the higher voltage to provide 12V charging.
02-23-2019, 09:19 AM   #3
photoptimist's Avatar
Is there a reason for 12V? These days, most bicycle accessories (lights & GPS/computers) come with USB charging and USB power banks are easy to get.
If you are feeling hackerish, you could cannibalize a USB bicycle light for its built-in USB-to-LiIon battery charging circuit to charge a Q battery.
The other solution is just to bring a few spare Q batteries (which may actually be lighter than any charging kit).
02-23-2019, 09:23 AM   #4
jlstrawman's Avatar
Pentax Q on USB powerbank? - PentaxForums.com
Camera Chargers & Cradles for Pentax Q | eBay
https://www.amazon.com/Battery-Charger-Pentax-Digital-Camera/dp/B0793CD19H
02-23-2019, 11:01 AM   #5
This may do the trick. Thanks!
02-23-2019, 03:01 PM   #6
Unless you are really off the beaten track, there will be any number of 110 VAC sockets around (motel, gas station, restaurant, library, ...). The regular Q charger plus the AC cord is pretty compact already! If desired, you could significantly shorten the cord - cut out most of the wire and splice the end plugs together.
02-23-2019, 05:06 PM   #7
I think you already found one answer above. Here's another. Wasabi chargers include a 12V car plug as well as the normal 110V.
https://www.amazon.com/Wasabi-Power-Battery-Charger-D-LI122/dp/B005D9DBI6?tag=pentaxforums-20&
02-24-2019, 02:53 PM   #8
QuoteOriginally posted by AstroDave Quote
I'll be on a bicycle and camping so I'm trying to lighten my load and charge from a solar panel while I ride.
I ended up ordering this:
https://www.amazon.com/Kastar-Battery-Charger-Fujifilm-FinePix/dp/B01KGH1EOM...r=1-3-fkmrnull
The Fuji NP-50 battery is compatible with the Q and seems to have more options for it.
02-24-2019, 05:46 PM - 1 Like   #9
A USB powered charger with bonus feature LCD display indicating to you the progression of how much the battery is charged is nice.
Happy travels! Can you drop us a review after you come back regards how well it works for you.
02-24-2019, 06:19 PM - 1 Like   #10
Abbazz's Avatar
QuoteOriginally posted by johnmflores Quote
Yes, I usually travel with my Fuji W3 (3D camera), Instax SQ10 (instant camera and printer) as well as a couple of Pentax Q bodies and assorted lenses. I find this kit very convenient because all three cameras use the same lithium-ion batteries and I only need to bring one charger (mine connnects to a standard USB plug and has a double charging slot).
Cheers!
Abbazz
02-25-2019, 12:01 PM - 2 Likes   #11
retired sw engineer
reh321's Avatar
amazon.com : Kastar Battery (X2) & LCD Slim USB Charger for Fujifilm NP-50 BC-50 BC-45W and Fuji FinePix F200EXR F75EXR F70EXR F100fd F60fd F50fd XF1 XP100 XP150 XP170 X20 F605EXR F660EXR F775EXR F900EXR Cameras : Electronics?tag=pentaxforums-20&
I have that Kastar charger - it permanently lives in my Q-7 bag and does a great job.
My "emergency" source of charging is a Ray-O-Vac device that creates a USB power source from 4 AA batteries, because I can get them everywhere.
02-25-2019, 05:19 PM   #12
QuoteOriginally posted by reh321 Quote
Any idea about how long does it takes to fill a flat battery?
02-25-2019, 08:49 PM   #13
retired sw engineer
reh321's Avatar
QuoteOriginally posted by 2old4toys Quote
No. I don't allow mine to get that 'flat'.
This is an "emergency only" system for me.
I've tested it take make sure it works, but I've never taken a battery all the way from low to full.
My sense is that it is noticeably slower than the Pentax charger, but I would use it only if 110 volt is unavailable.
camera, ebay, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7
Machinery Charging up............. eaglem Post Your Photos! 6 07-12-2017 03:29 PM
Options, options, K-1, 24-70 or 31 Limited. lesmore49 Pentax SLR Lens Discussion 13 03-10-2017 08:30 AM
K5 - USB or 12V Battery Recharging PentAdam Pentax Camera and Field Accessories 4 12-26-2012 05:16 PM
DIY K-5 Power Supply from 12V battery atnbirdie Pentax K-5 19 12-14-2012 10:18 AM
12V Cigar lighter philippe Pentax Camera and Field Accessories 6 05-23-2010 07:52 AM
All times are GMT -7. The time now is 11:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
