Originally posted by BNBPhoto I have researched the issue and found no answer except "buy another one". Is this a known issue and more importantly, is there a fix for it ?
It is a known issue and no, probably not. Usually they go completely dead, you can't even manually focus. Mine went out after about 4 hours of use as well, although that might be a coincidence.
I've bought two more, they have been OK so far.
I think that the 06 was just a little under-engineered; it seems flimsy compared to the 01, the 02 and the 08. Some posters here haven't had any problems with theirs, maybe it was a bad run?
I took my broken one apart and it is all plastic and circuitry inside, I think the circuitry goes bad for some reason.
