Good Job ! Sincere Congratulations 2old4toys !
Originally posted by 2old4toys ... some glass to cover up the sensor ASAP after removing the ir cut filter to reduce chances of contamination...
The rubber gasket under the ir cut filter is not glued in place at the base but lightly adhered to the glass...
Originally posted by 2old4toys Further notes.
... Not so keen on the alternative to shave the mount thinner if I can avoid it...
Sometimes, appearances are misleading ?...
Are you able to count the number of Dust Particles on your Photo #3, 1st Post ?
Particles are already visible on sensor... guess on a cover glass ?
I'm lazy... I choose the simpliest way to get the focus on sensor w/o any complication
... you just have to thin the bayonet mount... until the pictures are Sharp !
Reversible by putting a gasket of the exact thickness removed
Originally posted by barondla ... Was playing around shooting some prepared microscope slides last night. Could the ultra thin cover glass work well as a filter replacement for the Q ? They are small, very thin, and optically as perfect as possible...
Hi Barondla !
I too played with a microscope a long time ago when I was teen...
So I too had that idea, but...
- How to Clear the Particles off the inside of the Rubber Bellows, Post#1 Photo#3 ?
... of the sensor's Protective Glass ?... of the Cover Glass ?
- How to know the Refractive-Index of the Dichroic-Filter used by Pentax ?
... a special Dichroic Filter that let pass all the useful light througth
- How to fit the Cover Glass exactly parallel to the sensor ?
... once you've cut the ledges off the Filter Box...
- Everything is smaller than fingers !
That said... I would like to see the Difficults, hem.... Ooops ! No, the Results !
After a looong Brain OverHeat... I was able to add 1 page to my site
Samsung-NX-mini-M48-or-M42-Mount-Adapter Photos tagged with "nx-mini": Galleries: Digital Photography Review : Digital Photography Review
Good Luck, 2old4toys !
