11-08-2019, 02:05 PM   #1
Leumas's Avatar
Old 50mm Macro
Anyone used one of the 50mm manual macros on the Q? If so what were the results?
11-08-2019, 04:28 PM - 1 Like   #2
Here are a couple of shots. Not the/an old macro, though: this is with a SMC Pentax-FA 50mm F2.8 Macro with a touch of fungus inside, and the genuine Pentax Adapter Q for K-Mount Lens. I doubt which lens makes much difference.
These are the full Q7 frame images (4000x3000, reduced to 1280 wide in Photoshop Elements to fit Forum rules - and probably reduced further for actual posting).
Here are 1 mm marks on a ruler, so the total frame width at maximum macro is a bit more than 7 mm wide
And here's a zoom in on a really small bolt (seems too grandiose a term for something so small, but technically, I wouldn't call this a screw!) that is about 3mm long and about 1.5mm in diameter (total width across the threads)
These are at f 5.6, so diffraction is starting to hurt the resolution. Smaller aperture would help depth of field, but at a trade-off against diffraction.
Of course, you should use a tripod for this. Attaching one to a Q can be a bit tricky though - my tripod plate is too big for the bottom of the Q when the K adapter is attached - the adapter and the plate want the same space. Fortunately, the adapter can be fitted with the same tripod foot that the DA* 300mm F4 uses. Even more fortunately, I have a DA* 300 from which to borrow the foot!
11-08-2019, 09:36 PM - 1 Like   #3
kwb
I shot some tiny things with SMC-Pentax M 50mm F4 Macro, genuine K-Q adapter and Q7.
Tiny metallic green fly on a strawberry leaf by k kwb, on Flickr
Roadside aster(?) in the evening by k kwb, on Flickr
Aphid on a pink strawberry flower. by k kwb, on Flickr
There are some others on my flickr stream:
Search: pentax m 50 f4 macro | Flickr
11-08-2019, 09:38 PM - 1 Like   #4
kwb
You should also check out the adapted lens reference thread table.
Adapted lenses tested on the Q : the reference thread - PentaxForums.com
11-08-2019, 10:16 PM - 1 Like   #5
Leumas's Avatar
Those are some sick shots KWB
11-09-2019, 05:05 AM - 1 Like   #6
QuoteOriginally posted by kwb Quote
Aphid on a pink strawberry flower. by [URL="https://www.flickr.com/photos/134270895@N06/"]k kwb[Superb on Flickr
Superb use of the 50 macro lens kwb. Particularly like the fly & pink flower.
Thanks for sharing,
barondla
11-09-2019, 12:53 PM   #7
Leumas's Avatar
Any cropping involved in those shots at all?
11-09-2019, 06:52 PM - 1 Like   #8
kwb
Thanks barondla and Leumas!
QuoteOriginally posted by Leumas Quote
No, I didn't crop these.
50mm, camera, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7
Macro Old K20 macro With other old attachments old4570 Post Your Photos! 3 07-01-2018 05:08 PM
For Sale - Sold: Pentax 50mm Galore. **FA 50mm 1.7, DA 50mm 1.8 & FA 50mm 2.8 Macro jjdgti Sold Items 9 08-05-2013 04:41 PM
Zeiss Macro 50mm f/2 ZK Macro-Planar T* vs Pentax-A 50mm Macro kbrede Pentax SLR Lens Discussion 13 07-10-2012 11:07 AM
Just got 100mm F2.8 Macro, should I keep my old 50mm Macro? umeuph Pentax SLR Lens Discussion 17 06-05-2012 01:32 AM
All times are GMT -7. The time now is 04:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
