Originally posted by tvdtvdtvd The contacts may look perfect but a quick wipe of said contacts, on both body and lens, would be worthwhile.
Thanks, I gave that a try, to no avail. 8-)
---------- Post added 01-22-20 at 12:10 PM ----------
Originally posted by vonBaloney Possible firmware issue? That lens did have a firmware upgrade I think, so make sure the body is also up-to-date.
Thanks, I had recently updated my Q7 firmware. Unfortunately you cannot update the lens firmware if the body doesn't mate with it.
---------- Post added 01-22-20 at 12:11 PM ----------
Originally posted by 2old4toys When mounted does it make any noises when you press the shutter button?
Upon mounting the 01, it asks for manual entry of the focal length.
---------- Post added 01-22-20 at 12:14 PM ----------
No noises upon starting up or pressing shutter. 8-(
---------- Post added 01-22-20 at 12:16 PM ----------
Originally posted by reduno Do you even see light through the lens when mounted to a camera? I purchased an untested 06 where the electronic shutter did not open when the camera was turned on. I returned that one to the seller for a refund, rather than trying to dismantle and attempt a repair.
Exactly that, no light passes through it when mounted.
