Loaded with 2 filters, the Nisi holder transports nicely in it’s box.
Note this is the same 49mm threaded holder as recently revised for the Ricoh GRiii (earlier version just friction fitted and would fall off upon lens retraction.) Should be pretty adaptable for a lot of small compact cameras for those willing to experiment.
Encouraged by my preliminary findings mounting directly onto the wider Pentax 08 lens, I’d assumed the narrower view standard 02 would have been plain sailing. Not quite. I am utilising an old no-brand 40.5-49mm metal step up ring, so the Nisi holder now seats further out from the front element
It’s mostly fine with a 02 on a Q/Q10. Only a hint of dim corners at the widest 5mm end, that clears up at 5.5mm.
On a QS-1 though, my step up ring combined is clearly introducing more vignettes between 5m and 6.5mm.
Handholding the bare filter does away with the vignettes at the wide end.
So no serious concerns when using on a Q/Q10. Ideally I would like to get the Nisi holder closer to the 02’s front element for it to work better at the wide end on a QS-1.
Will be trying on the 01 prime next.
