Originally posted by jimfellows I was updating all the firmware on my camera's over the weekend (I truly live the dullest life) and I did notice that there is a firmware up date for both the 01 and 02 lenses. I don't know if this will help or cause a bigger issue if the lens has bad connections. Maybe setting the camera back to default wit the lens on it.
Good luck,
Jim Fellows
Hey,
Jim, thanks for the suggestion but I'm pretty certain it's not a firmware problem. The lens worked fine before this suddenly happened (which seems to suggest the firmware was fine) - and now, literally, it doesn't work at all. It's either some fatal internal problem (I shudder to think) - or, most likely, if I'm lucky, possible really getting the lens contacts cleaned.
Incidentally, in the 'wrench' Menu, there is a setting to check 'Firmware Info' - but right now, it only reveals the Q7 camera body firmware, and there is NO option whatsoever for checking the lens firmware - I suspect this is because the lens isn't making contact with the camera at all (because of the 'contacts' not working). If (and hopefully when) I do get the lens working again, then I'm hoping the lens's firmware info will show up as well.
Originally posted by brainwave I learnt something a while back which may help - in debug mode there are deep settings for autofocus tune, which can possibly allow you get the camera to nail focus. I do not however, know how to enter it or what to do there, maybe some more experienced members can help.
Hey,
brainwave - thanks for the suggestion - I've already gone through pretty much every possible setting for any kind of focus tuning - not just autofocus but manual as well - with zero results. To repeat the problem: it isn't just the AF which isn't working at all (in any of its multiple menu iterations) - the MF or manual focus isn't working either, at all.
Originally posted by barondla Bummer. Cleaning the contacts is the first thing to try. Also make sure the lens is completely seating on the camera. A slight mismatch would cause the body and lens contacts to "miss" each other.
Make sure the camera isn't in any weird settings that would affect af. Things like timer, wireless remote, etc. I would do a factory reset to return the Q to normal.
Unfortunately there is more to the lens af system than electrical contacts. There are electronics on a circuit board, behind the plastic lens mount. There is also the af motor. Q use focus by wire on af lenses. If the motor is inactive the lens can't manual focus.
Deposit is great. Use the absolute least amount possible. A very fine film at most.
Good luck,
barondla
Hey,
barondla! Thanks so much for your thoughts and suggestions!
I've ordered some DeoxIT (none of the local hardware stores carry it) but should have it in a few days - and hopefully it will be more eficacious than the isopropyl alcohol (which, alas, didn't work at all). I've been making very sure that the lens is 'seated' correctly when I attach or mount it, so I doubt there could be any issues there. I thought about the self-timer and the wireless remote (and all those other weird settings, too) - they were some of the first things I checked, but none of them were or have been activated, so they can all be ruled out.
I'll report back once I receive the DeoxIT - and thanks again for the tip about only using a fine film.
I'm keeping my fingers crossed (gulp)
