05-15-2021, 04:36 AM   #1
What mm do you tell at start up
So when you are using an adapter, say M42 to Q with a 50mm lens
Do you tell it at startup you're using a 50mm or 275mm or something else?
Thanks
05-15-2021, 04:51 AM - 2 Likes   #2
amateur dirt farmer
pepperberry farm's Avatar
a 50mm lens is always a 50mm lens - the only thing that changes is your field of view....
05-15-2021, 05:19 AM - 2 Likes   #3
For SR put the actual focal length. The camera understand what to do.
05-15-2021, 10:09 AM   #4
The only time you'd specify something different would be if you had a teleconverter (e.g. 1.4x) or an inter-series adapter with a lens in the middle, and those are hard to figure out unless specified by the manufacturer.
05-15-2021, 11:04 AM   #5
Michail_P's Avatar
The field of view is the less important part. In the end, youíll adapt to it. For me image quality is more of a concern. Luckily this isnít the case with M42... so observe and adapt your approach.
05-16-2021, 03:08 AM   #6
But what if it is a zoom lens? Are you better off telling the camera it is a 50mm or say 200mm? Assuming the lens is 50-200, that is.
05-16-2021, 03:33 AM   #7
QuoteOriginally posted by peggers Quote
Technically, you should enter each focal length as you change zoom, anything else is simply a compromise, which may or may not be better than not using the feature at all.
Remember, 'Shake Reduction' is a relatively recent concept in the history of photography Ö very many very acceptable pictures were made before SR was made available to the general public. A simple reversion to "basics" and utilising an appropriate shutter speed for the prevailing conditions will often obviate the need for SR
50mm, camera, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7
Your vehicle: what do you have, why do you like it, and what do you not like? Auzzie-Phoenix General Talk 2461 3 Days Ago 11:58 PM
Nature SEQUENCE : 180 mm - 90 mm - 45 mm on the Batiscan River, CANADA. RICHARD L. Post Your Photos! 5 12-20-2020 01:55 PM
Nature Isle aux Coudres @ 28 mm, 45 mm and 63 mm FL with DFA 28-105 mm HD and f/16. RICHARD L. Post Your Photos! 4 11-12-2020 09:37 PM
For Sale - Sold: Brand New FA 31 mm, FA 77 mm, DA* 60-250 mm, DA* 300 mm ppkkcao Sold Items 14 11-02-2014 08:42 PM
Do you start the timer when you start pouring? Jamey777 Film Processing, Scanning, and Darkroom 11 12-20-2013 11:40 AM
All times are GMT -7. The time now is 07:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
