07-05-2021, 07:55 AM   #1
Live view tethering of Q
Hello, long time since I was here although I’ve always followed this section. I’ve recently taken up microscopy and would like to use my original model Q to photograph specimens through the trinocular tube. What I’m asking is does anybody have experience of using a Q with a monitor as the focusing aid?
Can my Q be connected to a monitor and be used in this way?
Is there anything I need to know?
Thanks in advance, kind regards, K33F
07-05-2021, 08:28 AM   #2
i_trax's Avatar
as far as I know , the answer is NO.
All earlier Pentax's cameras would feed HDMI out on playback only.
07-05-2021, 09:29 AM   #3
kayakfari's Avatar
You can connect to a TV monitor with AV cables.
I did this to test the functionality of a Q with a broken screen once. HDMI will not work however.
Can I hook up the camera to an AV device and leave it connected while shooting pictures?
Yes. To view an image on an external monitor while capturing it, connect the camera to an AV device with a video terminal. You cannot output images using the HDMI terminal while capturing pictures.
Q10 | FAQ | Support | RICOH IMAGING
07-05-2021, 09:36 AM   #4
i_trax's Avatar
The AV cable will give you video composite quality ( copy of the image on the back LCD screen ), very low resolution.
Not much use for anything. You need HDMI out quality.
07-05-2021, 09:49 AM   #5
QuoteOriginally posted by kayakfari Quote
Thanks, I’ll pursue that route, hopefully it will meet my needs. The camera on top of my trinocular would just be so high that I wouldn’t be able to stand tall enough to focus normally.
---------- Post added 05-07-21 at 17:53 ----------
QuoteOriginally posted by i_trax Quote
Thanks, I’m hoping it will be sufficient just to confirm focus. I will be doing all my composition using the binoculars and getting rough focus, then using the monitor to confirm the camera has got focus. I’m happy to experiment, the ultimate aim being to achieve a parfocal arrangement which will simplify things greatly.
07-05-2021, 11:35 AM   #6
QuoteOriginally posted by keithlester Quote
Can you lower your microscope setup (on a lower table/platform or even the floor)?
07-05-2021, 11:57 AM - 1 Like   #7
QuoteOriginally posted by AstroDave Quote
Lol. I’m 70 years old, bending that low and standing up again forty-leven times an hour would finish me off in a week. It’s bad enough using a cellphone camera mounted on a flat adapter. I wouldn’t need to do it at all but the cellphone camera is limited in its usefulness. I’ve established that I can produce an image, but now I want to produce the est image that my resources will allow. I can’t justify, or even afford a top end DSLR with tethering, so my Pentax Q solution is the best I can afford. I have to try it, even if it’s not successful. At least I will have tried my best.
07-05-2021, 07:46 PM - 1 Like   #8
For ref: I hooked up an external tilty LCD monitor via the av wires from a Q for live view and it kinda works ok for focussing in conjunction with the Q’s zoom function
Q cage - PentaxForums.com
07-05-2021, 09:46 PM - 1 Like   #9
Or low tech use a mirror. I have this small one on a bendy stalk that slots into the hot shoe and allows you to view the rear screen from an angle. It was an accessory that came with a very old school selfie stick for little point and shoots back in the day. Polaroid Camera Extender Self Portrait Handheld Monopod w Mirror Extends to 37" - Newegg.com
07-05-2021, 09:50 PM   #10
Thanks to everyone who responded, I’ve got the information I need.
kind regards, K33F
07-06-2021, 07:21 PM   #11
QuoteOriginally posted by 2old4toys Quote
Neat gizmo!
Thanks for sharing,
barondla
av, camera, focus, hdmi, micro photography, mirrorless, monitor, pentax q, pentax q10, pentax q7, q-s1, q10, q7, quality
Still no realtime Live View when tethering the 645Z ? zobeleye Pentax Medium Format 4 01-16-2018 03:33 AM
live view noise and smc dfa 100mm f2.8 macro lens not focusing in live view tommygunn84 Troubleshooting and Beginner Help 7 11-24-2016 08:59 PM
Typical live view humming, when not in live view. lightsource Pentax K-1 & K-1 II 8 05-05-2016 02:20 AM
K5 Live View: Live Exposure Adjustments Visible in "M" Mode? godwinaustin Pentax K-5 & K-5 II 6 08-13-2013 08:11 PM
View finder vs Live View on K5 II Wingincamera Pentax K-5 & K-5 II 5 12-08-2012 03:47 PM
All times are GMT -7. The time now is 12:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
