One of my lens brushes began shedding hairs. Seems that a little bug of some sort had made a nest and done some trimming.
Not being set up for micro photography, I made use of a 10X Lupe to help my Q10 and 5mm -15mm lens to take photos of the nest, which was approximately 1.5mm in size.
Although not perfect, the result was OK as far as I’m concerned.
Re this post.
I realize now that I overcooked the operation. I didn't need the tripod, it only made things more difficult. I've just found that I can sit the Q10 lens directly on top of the Lupe and get a better result.
Sorry if I misled any one. It seems so obvious now
Reason: Offering a simpler method (which you probably knew)
