Hey Elias, welcome to the forum! I'm a lazy current maintainer of
Q Adapted lensesreference thread.
In that thread,
Pentax C30811KP 8.5 f1.5 C mount CCTV lens looks good to me. There's no example of Cosmicar 8.5mm f1.5 C mount CCTV lens (w/o Pentax logo on the barrel) in the thread, it seems to be cheaper and somewhat more widely available, but I don't know if it's the same lens as C30811.
Though the sample picture is gone, the user who adapted CS mount
Cosmicar 6mm f/1.4 seems to like it.
When adapting lenses other than Q mount, there are a few things you should know.
- Q 01, 02, 06 and 08 lens as well as the OEM K mount adapter have mechanical shutter built in, and you can use mechanical shutter as well as electronic shutter. Other lenses don't have mechanical shutter as far as Q is concerned, and you'll be using electronic shutter.
- When using electronic shutter, the rolling_shutter effect could be rather severe depending on the subject. See attached for example. No such effect using Q lenses' mechanical shutter.
- Slow shutter is limited to 2 seconds for electronic shutter, 30 sec for mechanical shutter.
- Flash sync speed is 1/13 sec for electronic shutter no matter what. With mechanical shutter it's 1/2000 sec for built-in flash and 1/250 sec for external flash.
- Q 01, 02, 06 and 08 lens have in-lens ND filter you can switch on/off from the camera to attenuate the light by 2 stops. This comes very handy for bright scene and for slow shutter.
Q 01, 02, 06 and 08 lenses (as well as OEM K mount adapter though it doesn't have ND filter) offer these advantages. OTOH, one drawback of 01 lens that I sometimes feel is that its geometric distortion is not small, though I don't know if non-Q alternatives are any better in that respect.
Good luck for your search, and if you end up adapting some lenses, don't forget to post to the reference thread!
