Originally posted by 2old4toys
The 02 is the cheapest and surely the most commonly available of the Q lenses, whilst the 06 seems the most failure prone.
Good luck with that 02 dismemberment and share you findings here!!!
Oof. Well, that may have been a pointless sacrifice. It started so well.
Disappointingly, even with all of the assemblies intact post disassembly it doesn’t reliably work. I’m not even sure why, they made the camera lens communications way too smart for this little thing. I was just hoping to tuck all the parts away either in or outside of a mount adapter cheaply, just to get the exposures past 2 seconds. They should have just made that a firmware fix. Oh well. The little parts all work, when it decides to get past the startup, but I can’t tell what is failing there and I spent too many hours testing combinations. I’d recommend not disassembling one of those I did get frustrated with one ring and it broke but I never intended to put this one back together.
