I had a 5-15mm suddenly stop focusing, AF or MF. I decided to tear it apart and figure out why.
The flex connectors on the circuit board near the mount, which are easily accessible, were all snugly connected. They don't seem like a weakness that would be likely to fail, so my hopes of a simple repair were dashed.
Going further, I knew I was going past the point where it would be easy to get the lens back together properly. At the very end, making it all the way to the front of the lens, I found the cause: a flex cable that had cleanly broken. The edges are a bit bent, so it broke right where it flexes. It just flexed too many times to survive.
I don't know if Pentax even offers this flex cable as a replacement part, or if it would also need to come with the focus motor, but it's buried so far into the lens that even if you could get the part, the chances of getting it back together properly, and the time required to do so, if you were paying a skilled technician to do it, make it not worth even attempting.
If I have any other Q lenses that stop focusing, I'll do a quick check for disconnected flex connectors on the circuit, but I'm not hopeful, and if they're all connected, I'll consider it a lost cause.
The macro shot of the broken flex was taken by holding the rear lens group of the 5-15mm up to my cellphone's camera lens, using part of the broken lens as a diopter to photograph other parts of itself.
As an aside, I must say I am quite impressed with the tiny mechanism that is the aperture, shutter, and ND filter.
