Originally posted by Clavius You find passing a optical signal directly through a mirror&prism more complex then:
converting a optical signal to electronic, running it through loads of software - mostly not even controlled by the user - then converting it BACK to optical again by outputting it via a sh*tload of tiny flickering lights?
Er, the point is that the signal is
already in digital form, and indeed a large part of the camera's expense has been getting it there. So using an EVF is taking advantage of that situation. And indeed, the mirror/etc on an SLR
is complex (in practice, if not conception), expensive (which of course is why the OVFs on non-top-tier SLRs tend to be kind of cramped and dark), quite large, and somewhat fragile.
Quote: You find the EVF of the V1 and the A77 excellent?! And hard to distinguish from OVF?! You must wear glasses of over and inch thick then? Or maybe you shoot only landscapes in bright daylight?
In both cameras anyone immediately sees that it's an EVF. And when you pan even just a tiny bit it immediately becomes extremely obvious that one is looking through an EVF.
orrrrrr you're just engaging in a bit of hyperbole... and sure, these EVFs aren't perfect, but they are
quite good (strobing effects from electronic displays etc, are one of their weak points, for instance, although that isn't something I'd generally care about in actual use), and offer a different set of tradeoffs from OVFs. On many mid-tier DSLRs, for instance, the OVF is kind of small and dark, whereas EVFs are much easier to make large and bright. Panning lag can be a problem with older EVFs, but I haven't noticed it to be an issue on current good EVFs (e.g. V1/A77 -- and yes, they are quite good).
Anyway, the beauty of it is that we don't need to agree. I have my standard for what I consider acceptable, and some current EVFs seem to meet it. You may have different standards/uses, and may disagree with me about certain models -- but EVFs have a lot of room to get better at acceptable cost (faster update speeds, higher resolution, etc), and as long as enough people agree with you, they
will continue to get better....
