Originally posted by Heie Uhm....you already have all of that. I completely fail to recognize what is so "crippling" about the way the ISO and compensation is adjusted on the K5 currently. I don't use the camera as much as I should (I spend way too much time on online forums reading about photography than actually doing it
), but when I am shooting, I still have never had a problem adjusting any of the the big 4 paramenters (ISO, Shutter Speed, Aperture, and compensation), neither accurately (the parameter that I intended to change) nor quickly/efficiently.
I never said the current way was crippling, I said I wanted separate physical controls. (I did say it had a crippled mount, which seems to be the generally accepted term. I'll rephrase it as "add back the aperture feeler to the mount" if you want. Of course that would make old lenses better than new lenses, so a third wheel seems like a more likely option. Not that either is actually going to happen.)
To be clear, I want to be able to teach my fingers where the controls are. This means they can't move between modes (not the ones I use anyway), and they have to be separate, not the same ones with a qualifier. I've had the K-5 long enough to be sure it will never be as easy for me to adjust the ISO as the other two (in M, which I usually use).
