Originally posted by Vylen Science is to figure out "why" from what already exists.
Actually, science looks for the 'how' something works. 'Why' is for theologians.
Originally posted by Douglas_of_Sweden Isn't most troubles in lens design resulting from us insisting on projecting the image on a flat surface?
I recall discussing this a couple years ago, with suggestions for curved sensors. Would a concave frame with spray-on thin-film circuitry be so hard to make? Probably yes.
Besides our eyes, some of us have used curved frames before: oatmeal-carton
pinhead pinhole cameras. An 8x10" / 205x255mm (325mm diagonal) sheet of photo paper in a 5.25" (diameter) x 9.5" (height) carton has a 135mm focal length projecting onto a 'frame' in a cylinder of 16.5" / 420mm circumference for almost 280 degree coverage.
But image edges get dim. Edge light falloff is a bit less if we trim the photo paper from 10" to 9" / 230mm (308mm diagonal) and insert the paper lengthwise in the carton. Now the corner-to-corner coverage is closer to 180 degrees, an infinite-DOF fisheye. And illumination is pretty even across that frame.
Alas, a cylindrical frame would require non-simple optics for proper image projection. So we still need that concave frame for a simple lens. Ah, for the next fab breakthru...
