Originally posted by boriscleto The Nikon version will most likely mount to a K mount camera just fine...
As long as none of the external tabs or flanges are present this should be true (and there is no real reason to have them present). However as I recall the locking pin on Nikon is on the opposite side from Pentax bodies so in order to lock the lens you would have to rotate it 180 degrees. Perhaps the mount can be rotated 180 degrees - it depends on how the mounting holes are spaced.
Vignetting effects go a bit beyond "bokeh" (of course it depends on how you define the effect). The curved field of focus means that pretty much only the center will be in focus. Certainly not a lens you would want to photograph documents with.
