Night shooting is thrilling and fun!
You get to a location, it might be dark or getting there.
You have your gear.
You have your routine, your photographic workflow.
Most of your gear changes will be done in darkness or with limited visibility.
How your equipment works together should be rehearsed and familiar.
Take only what you need but be prepared.
If you drop something in a field or in the woods, it will be lost; forget about it if you can't find it dropped on the ground immediately.
The later it gets, the cooler it gets - are you prepared for the weather?
Condensation on the lens and camera need to be wiped away.
Bugs. Mosquitos. Critters.
People may not like you being around or you might be in a location that will surprise someone.
Make sure your camera is level.
Make sure your tripod is steady.
Don't put anything down on the ground if you can avoid it - critters.
Bring a stool as you don't want to sit on damp unknown ground.
Battery power and backup.
LED lights?
Flash?
Flashlight/torch?
Use an LED headlamp so your hands are free.
Make sure you have an exit plan if you are in a place that "locks up after dark".
Turn off your cell phone or silence it.
Wear dark clothes.
Have someone know where you are shooting and expected time of return.
Have bail money (with a friend) and limited ID on you.
If you can shoot with someone who does not have a camera and is a "look out" - great.
If you are shooting in a ruined Castle/Abbey/Cemetery, keep your cool and try not to be afraid.
Lots and lots more if I think about it.
