Originally posted by theWags I have started making a few bucks taking real estate photos. My problem is that I carry an extra lens or two (e.g., a wide angle) and switch for different rooms/views. Same problem in the field, where I use my walk around zoom, but occasionally switch to a macro. I have not found a convenient method for lugging around just an extra lens or two. Any suggestions? Has anyone had any experience with some sort of belt with lens hangers? I see some ads, but they always seem to have two cameras hanging on them, not lenses. Any suggestions appreciated.
Thanks,
Will
When I know I'll be using just 2 lenses (or one specific lens predominately + plus "others"), I take 2 bodies. That minimizes or eliminates fiddling with changing lenses at all.
Surprisingly, I've found that things balance better with two bodies, rather than just a lens dangling from my hip.
Granted, almost all of my lenses require 77-82mm filters, so they aren't small, but 2 cross slung bodies are really easy to use.
They also make vests and other gear specifically for the dual body shooter.
I actually got the idea from a couple older pros I was lucky enough to tag along with early in my digital days.
