Thanks for all the responses. I actually enjoy the differing opinions amongst people (even if it doesn't make the decision easier), it just comes to show how different opinions can be from photographer to photographer. No for some replies.
Originally posted by LeDave Woah! had no idea it was that heavy. I would say if you're able to manage it then go right ahead. I'm just stating this as my opinion, if I were in your spot, I would lug it around with me and try to fight through the tiresome and painful dwelling of having it on your side. Because in the end it'll be all worth it once you load all those pics up on Photoshop or Lightroom, you're going to be proud of your lens and your work.
Indeed, the 70-200mm is one beast of a lens (only in specs though, I'll need to use it to make any reliable comments), actually, to be honest it was my main justification for purchasing the 60-250mm lens in the interim to the release of the 70-200mm. I figure, if I am going for a hike, or I'm in broad sunlight (a common occurrence in Alice), the 60-250mm would be a more flexible lens, having a wider focal length on both ends and being much lighter. That said, the 70-200mm would probably give more control of DOF and should have much more reliable autofocus (not that the 60-250mm is bad, it's just no speed demon). So many choices, thankfully I have time to decide before the wedding.
Originally posted by esrandall Bring what you think you'll use the most. You'll want to spend less time changing lenses, and more time catching shots to supplement what the primary shooter will be doing. I'd bring the 16-50 and the 60-250, and call it a day. You could invest in a Cotton Carrier, pick up the optional waist-level holder, and carry both cameras on your body. Being the secondary shooter, I would think that you'd get a lot of mileage out of the 16-50 alone. That will probably stay on your K-3 most of the day. There are plenty of people with wedding experience that will surely offer up advice. I would think that a single K-3 (with a couple batteries), the two aforementioned lenses, and maybe a flash (in case things get late, and light goes by the wayside) would be all that you would need. You have an outstanding collection of gear, and those three pieces should serve you well.
So in your opinion, you believe that a more minimalistic equipment set would be a more reasonable option. Is that because you think it would lead to more creative improvisation, or because it would be easier on my back (or both)? Also, do you think that a second body would be going over the top?
Originally posted by aleonx3 IMHO, you don't need to bring any long lens, you will be close to action, unless you intend to take sniper shots. Wide to medium lenses are more than enough; you need fast lens though.
Unfortunately, as an outdoor ceremony (with a small section in a warehouse church), I believe that a telephoto lens may be required (I've seen the locale, and it's not lacking in space). That said, I don't currently have a wide lens in my inventory, would you say that would be a spot worth filling? And with what?
Originally posted by SpecialK The 18-35 and 28-80.
I must admit, those two lenses are absolutely fantastic. That said, I do find that the 28-80mm has an unusual focal range on an APS-C sensor, but then again, I haven't actually shot the Sigma and the Tokina together as a two body system, so maybe it'd be more versatile with that setup.
---------- Post added 08-25-15 at 07:45 PM ----------
Originally posted by johnmflores Cameras - the two K-3s. Same battery. Same controls. DA* 16-50 F3.2 on one K-3 DA* 60-250 F2.8 of DFA* 70-200 F2.8 on the other K-3. Pick the lighter combo. Sigma 18-35 F1.8 in the bag as a backup for the DA* 16-50 Pentax DFA 100 F2.8 in the bag as a backup for your telecom Some kind of cooling vest or towel discretely worn so you don't melt in the heat.
So far, it seems that the consensus amongst us Pentaxians is that the 16-50mm is preferable to the 18-35mm. I can, from personal experience, say that I can see why people would say that. The extra 1 1/3 stop in brightness from the 18-35mm is fantastic, as is the edge to edge sharpness, but the focal range of the 16-50mm is outstandingly versatile and it does weigh quite a lot less. On the 60-250mm vs 70-200mm, I guess other than the obvious weight discrepancy, the main thing of note will be the autofocus performance, and the optical performance of each lens, though I doubt that the 70-200mm will be substantially better in its optical performance when compared to the 60-250mm. As for the backup lenses, would you wear a shoulder bag (in my case, a Billingham Hadley Pro), or a back pack? Also, I love the humour on the heat.
Originally posted by macman24054 I shoot weddings at the rate of about 2 per month. Here is what I carry. 3 bodies (KS1, K30 and K10D or K01 if a quiet shutter is requested) Tamron 17-50 2.8 Pentax DA* 50-135 Sigma 18-200 DA 50 1.8 DA 35 2.4 Sigma 70-300 (only for macro use) Good lighting(speedlites, radio triggers light modifiers) , plenty of all batteries and a good checklist to follow are almost as important as the cameras and lens.
So in your experience, do you find that the faster primes are of more use than the zoom lenses? On the lighting side of things, I will most likely bring my Pentax 360AF with enloop batteries, but I must say that my skills with light modifiers isn't that fantastic. As to the checklist, thank you, that's a brilliant idea.
Originally posted by UncleVanya I am not experienced at this. I have shot only 1 wedding and it was done with a fast 50 as a favor to a friend when I was very young. The marriage didn't last so I have no way to look back and see how I did... Based on the heat and weight I think I would not try the 70-200. The DA* 60-250 is a fine lens and if this is an outdoor event it should deliver the goods But I'm just guessing. I'm not sure how much need for that long of a lens there will be. Maybe you could get by with the D FA 100 on one body and the 16-50 on the other.
I hope that isn't the case for the young couple to be wed, but nonetheless, we shall see. Also, you get used to the heat believe it enough, but you do have to be aware of it.
