Originally posted by Sterby What if Ricoh would take some of the old FA primes and release them as HD D-FA variants? Same optical design, new coating and new packaging.
I think they might do this for the FA Limited lenses
that are still in the current lens line-up. (As they did for the DA Limited lenses without pre-announcements in August 2013).
But once Ricoh have launched the 4 new FF primes on the Pentax FF roadmap, I think the main problem with the current Pentax FF lens line-up will continue to be the zooms. Of the 15 lenses on the current Pentax FF line-up, 10 are primes, 5 are zooms. That ratio is probably the wrong way round for typical customers rather than forum-enthusiasts.
I think Pentax FF zooms are needed in 3 (loose) categories:
1. Professional-standard or near-professional-standard FF zooms across the range. This has already been done well enough
for the time being with the 4 such lenses released over the last 15 months or so.
2. "Affordable" smallish/lightish FF zooms with high image quality across a more limited range. Perhaps 3 are needed, and we already have the middle one of them, the 28-105mm.
3. "Miscellaneous". There is a Fisheye zoom on the FF roadmap. Other people have made good cases for some f/4 zooms somewhere in between categories "1" and "2". (A D FA 60-250mm f/4 based on the current DA* 60-250mm would be "interesting"!)
Are there any old FA lenses that could be brought up to date as these extra zooms? I suspect not, or one or two at the most.
---------- Post added 1st Sep 2016 at 05:35 AM ----------
Originally posted by reh321 I believe FF will be Pentax's answer to landscape / portrait photography, so the APS-C line needs a reason to exist.
The APS-C line
already has good reasons (in addition to higher burst rates) to exist:
1. Cheaper, lighter, smaller. For many people, one or more of these is a good reason not to choose the FF line. (And the APS-C line has been capable of doing good landscapes and portraits for many years!)
2. Lots more Pentax lenses available. (There are about 40
current Pentax lenses that work fully on APS-C cameras, compared with the 15 of them that are officially FF lenses.
