Originally posted by Wasp We got a couple of pictures out of it for a few dollars. They were sent as JPEG files. Upon opening the first one something seemed odd. I zoomed in and sure enough, the eyes were out of focus! The hands and detail on dress was OK but the eyes were definitely on the soft side. The other picture was perfect, so I can't complain too much. I just wish that a bit of QA was done on IQ before releasing the pictures...
If you say that there were details on the dress, then the photographer didn't get the focus right on this image. Sounds like user error or too much confidence in his camera.
Originally posted by Wasp The EXIF data shows that a Canon EOS 5D Mark IV with a 200mm lens was used. The exposure was 1/250 sec. f/4.0 at ISO 500. Not much depth of field to work with, especially when shooting a model walking towards you on a cat walk.
The shutter speed may be a little long at 1/250 and 200mm but choosing the right settings for this particular shooting session depends on a lot of things (the available light, if the lens has image stabilisation or not, how fast the models are walking on the scene, etc.). The DOF at 200mm and f4 should not be a problem if you know what you are doing. Imagine that other photographers are shooting at f2.8 with 300mm lenses or with 400mm lenses in much more difficult scenarious.
Originally posted by Wasp I am not sure which model lens was used. I think it was a Canon 70-200mm f/4 L, but it might have been the f/2.8 L. I believe that autofocus was in use. That is probably where things went south. The camera's predictive autofocus algorithm doesn't always nail it.
Either way, if the lens doesn't have image stabilisation, a little more work has to be done to get sharp images at low shutter speeds (althrough 1/250s is somewhere in the middle when you shoot at 200mm - not too fast, not too slow).
As a 5D Mark IV user, I can tell you that the af is quite complex and you have to work a little with the camera in order to learn how to tweak all 6 Af cases to get the best results. Even if everything is set correctly, sometimes you may miss focus on moving subject. It happens on Canon, Nikon, Fuji, etc. Yes, it happens even with Sony Eye Af.
Originally posted by Wasp How would the best and brightest here have handled a shoot like this? Smaller aperture, more depth of field, yes. But how much smaller? Would f/5.6 be enough or would f/8.0 be needed? That would mean a slower speed. Would the image stabilization keep thing sharp at 1/125 or 1/60 sec? Or crank up the ISO, but how much more is OK before noise gets noticeable? Or just do what this guy did - shoot lots of pics and at least one will make the grade?
It is hard to tell without beeing there and see the conditions. For this type of shooting, getting the model in focus is not enough. You also need to get the best results when comes to:
- angle of shooting
- position of the model's legs
- position of the model's hands
- expression of the model
Personally, I would shoot 2 short bursts for each model (3-4 images on each burst) and I would use af-c (Ai Servo on Canon) with some adjustments on Tracking sensitivity and Acceleration/deceleration Tracking. I wouldn't use manual focus because it's hard to get the model in perfect position (hands, legs, expression) by focusing on a spot and shooting when the model passes on that spot. She may have the eyes closed or a bad position of the body and you will end up with a bad image.
