Originally posted by Rondec I tend to want less "cooking" when shooting RAW and could care less when shooting jpegs. The problem if, for instance, vignetting is corrected in the RAW, I'm going to run into noise in the corners way faster when I bump the exposure in post than I would otherwise. There is no free lunch.
Sure. That said, the raw vignetting correction (we can reasonably assume) is only lifting / recovering information that's there. If we find it too noisy, we can add vignetting in post and end up more-or-less where we'd have been without the correction - no? I'd have thought the vast majority of users would actually benefit from the vignetting correction, whilst the minority that didn't want it can counteract it.
Originally posted by Rondec The only reason that I can see to do this is to have review sites pretend that your lenses are better than they are. "Minimal distortion. The least vignetting we've ever seen with a f1.2 lens!" and so on. Except it is fabricated and since there is no way to shoot these lenses, except on these mirrorless cameras, it isn't even possible to know how much correction is going on behind the scenes.
Perhaps I'm being too charitable in thinking the benefit is at least partially aimed at the user rather than test results. I'd like to think it is, but I'm prepared to accept it might instead be for the reasons you mention. If that's the primary or even partial motive, I think it's a poor show. Still, if the raw files look good and respond well to processing, I'm willing to be open-minded about it.
I will say, it's a pain in the butt when I'm processing images for a lens with no profile available in the software I'm using. My choices are to manually correct distortion and vignetting (difficult to be precise - impossible, even, for complex distortion), or spend a lot of time creating profiles of my own when I'd rather be out shooting. That said, for the lens profiles I've created, I tend to deal only with distortion. I typically correct vignetting manually, and only then when I feel it's really necessary, as I quite like a mild vignetting effect on many of my photos.
All of this aside, I'd be happier if there were two options for raw capture... (1)
uncorrected raw (unlikely, since the results would probably frighten off a large part of the user base), and (2)
corrected raw. Plus, of course, flattened and compressed JPEG. Actually, you can add in one more option... I'd love a TIFF capability in all of my cameras. But that's just me
