Originally posted by StiffLegged Let's be honest here, this isn't going to fly.
Being 100% honest, I think it really can - if the mirror can be accommodated somehow without the limitations @Kunzite refers to above.
Originally posted by StiffLegged If someone wants to build an ILC that uses both optical and electronic viewfinders, there are just two likely ways to do it instead of building the Rube Goldberg devices mentioned above. (1) a viewfinder camera like a Leica M-series rangefinder with an additional EVF built in, or (2) a DSLR with an EVF which can be swapped with the pentaprism.
Option (1) already exists, sorta, with Leica's add-on OVF for the M10 variants. Option (2) doesn't, but is at least feasible: an EVF which can be swapped out with an OVF, with the mirror deploying or swinging out of the way as necessary. I imagine there are at least a dozen people fighting to be the first to own such a camera — perhaps some day they'll have their wish.
We've had long discussions before on these forums regarding a hybrid viewfinder, and how it might practically be implemented. I think something like this is just as likely as the options you mention, and arguably more attractive...
Originally posted by StiffLegged The likely progression of manufacturers to the mirrorless format is because it makes cameras mechanically simpler, therefore reducing engineering costs - the reverse of option (2). The next step will be when sensors can be read at a single step, rather than scanned. Then the gearheads and fashionistas will be able to boast of moving to a shutterless camera (no doubt at the usual premium), as they make the same images over again!
Frankly, with camera sales plummeting, I'm not hugely confident of on-going large scale developments. The cost of such developments will have to be recouped through sales, which means new, innovative gear (as opposed to mild updates of already-developed models) is going to be expensive. Much as I genuinely like Canon's idea, and I
do think there's a market for it (me, for instance, if I was a Canon DSLR shooter), I suspect it's going to be an expensive solution, making an already fairly limited market even smaller due to cost...
