Originally posted by FozzFoster My K-S2 generally shows more detail than my K-5. But that depends. I've noticed that on my K-S2 I see motion blur more easily, and I attributed it to increased resolution.
A 14MP APS-C camera doesn't show more pixel peeping detail than a 36MP full frame?
I might be in over my head here..
I don't understand.
I've seen noticeable differences not only between my K-5 (16MP) and my K-S2 (20MP), but also between my Canon SX50 HS (12MP) and my Mom's Canon SX60 HS (16MP).
Not always for the better, but there are generally noticeable positive differences for 4 more MP.
And I'd have a hard time imagining that I could not discern a half-way point (2MP) as well.
To tie this back in, you claimed that the Canon APS-C sensor pixel area being ~9.4% smaller than the standard APS-C size is only about the difference of a 2MP jump.
I am claiming I could probably notice a 2MP difference, since I can notice a 4MP difference, I imagine I could notice a half way point.
I think I know where the confusion comes from
There are two things that matter (the elephant in the room is sensor tech level which is very important and
really makes it difficult to compare across "generations")- pixel count and pixel area.
Higher pixel count of course increases detail captured, but there are a couple caveats:
-Keeping sensor size constant you will notice that detail captured is finer,
but you will see more pixel-level errors because the pixels are much smaller and, for example, what was before a sub-pixel vibration is now enough to smear the image. Or CA that barely took two pixels now takes 4.
-Keeping pixel area constant (the example I put) you have more total detail but you need a larger sensor. In my example, the 100% view doesn't look sharper on the K-1. This train of thought will inevitable devolve into the e-word so I'll stop it here.
My point with the Fuji example was that the "pixel level" measures - DR, noise - won't change a lot with the small change in pixel area. Of course, you will see more detail because of the increased resolution. However, a 24 MP camera, be it Canon or Pentax, will record roughly the same detail.
In any case, pixel peeping is wrong
