Originally posted by Ian Stuart Forsyth You did post a 1 stop difference in one of your post and then you even seen a difference but could not understand why
No, I'm talking about the 11 images I posted with a poll to see if anyone could tell the difference. It came out 50/50, guess work, with most people admitting it was guess work. The poll had ~90 responses. 90 people are wrong, you're right, typical.
Originally posted by Ian Stuart Forsyth This can be cone with FF also, in the very same light I can use the same shutter speed and DOF
If it's the same, there's no FF advantage.
Here I'll make it easy for you.
APS-c ƒ/5.6- 40mm@10 ft _ 100 ISO _ 1/30s _ DoF = 4.46 ft
FF___ ƒ/8 _ 60mm@10 ft _ 100 ISO _ 1/15s _ DoF = 4.15 ft
FF___ ƒ5.6 - 60mm@10 ft _ 100 ISO _ 1/30s _ DoF = 2.87 ft
FF has twice the opportunity for motion blur to achieve less DoF
SO what exactly can you do? You didn't say.
Maybe try it yourself
https://www.dofmaster.com/dofjs.html
Maybe post some example scenarios.
Shooting at the base ISO (for max IQ), same light is a worthless stat. It makes no difference to IQ. But that's how you frame it to try and make something out of nothing. Talk about a stat that has no practical meaning for your best shots. At base ISO or even 200 ISO or 400 ISO in most cases, there is no demonstrable difference. The 90 people in my poll agree. It's not just me.
If you leave out the total light nonsense, you have nothing.
I admit, you did trick me once by using "total light" instead of base ISO. Fool me once.....
I sometimes get caught by the sophistication of people skilled at deflecting. "Total light " is one such deflection. I could be proven wrong but my poll of 90 people showed this to be correct. Total light makes almost no difference to IQ across different formats (barring comparisons of degraded images at 64,000 ISO or something.) But I'll be happy if someone else wants to run a poll with 11 or more images, 5 pairs and a solo, to show I'm wrong. I like to deal with practical results. I just use the math to explain those results.
