Originally posted by Peter Zack The Nikon cable has an AF assist lamp built into the cable (hot shoe end) end. Pentax does not make any cables like this. Are you looking for the flash to assist you with focus? Then just put the flash on the camera shoe (AF360 or AF540) and use them as the AF assist lamp.
Btw, what lenses are you using? I've used some fast primes and zooms in some aweful light and can still lock focus without the flash.
Hi Yousuf,
Thank you for your response. I'm using the Pentax 16-50 2.8 lens. I believe that I was using the AF assist off of the flash of the AF-540 FGZ flash because I could see a broad IR pattern.
Just to test it out, I set the flash in SB mode and went in my bathroom and closed the door (near total darkness conditions). I could focus, but the flash wouldn't fire in SB mode. Is that the purpose of SB mode---use the flashes AF but not fire?
I've talked to a number of other Nightclub photogs and they have this same problem whether they're using Canon's or Nikon's. What's funny is that the non-dslr's seem to work fine in these conditions.
-Joe
