Originally posted by abieleck So they got rid of a mirror, so you could then attached a loupe viewfinder the the display screen? That doesn't make a whole lot of sense.
the idea of removing the mirror is to eliminate mirror slap. also for faster AF operation.
Quote: One dial? So you have to hold another button down with the dial to change aperture/shutter speed? Not sure why then brought the ISO button down. I use a D7000 at work and hate the ISO button placement, this isn't quite as bad as you can still use your shooting hand, but the K5 has it and the exposure compensation in the perfect spot.
I could live with one dial. and I don't believe you have to hold a button down to change aperture/shutterspeed. all it takes is a designated button to change parameters. it is not as complicated as you might think.
Quote: Even if they do make an EVF or OVF for the hotshoe, will it be obstructed if you pop the flash up or useless if you want to use an external flash?
I don't think Pentax made that an option.
Quote: I have not held one obviously, but I can't image using anything bigger than a limited lens with the absence of a grip of any sort. With heavier lenses I always carry the system by the grip on the K5. I could see people that use both the K5 and K-01 forgetting there is a non-existent grip and having the camera slip right out of their hands.
the build looks very secure. boxy, thick and has a rubbery grip. to be honest, the K-01 alone looks more secured to handle than the K-5 with or without a grip. I have the K-7 so I pretty much know or feel what could be better for handling.
Quote: I am trying to be optimistic but it seems like they stripped down a K5 of useful features and excellent layout, gave it to a designer to have his way with it, and market it to everyone at once without taking into consideration what people that already use Pentax are looking for.
every person has it's own preference. personally, I would had preferred something with an EVF as well, but it doesn't mean it's a dealbreaker especially for the K-01's size. the EVF would had been a dealbreaker if the K-01 is as small or slightly bigger than the NEX-7. but since it's still dslr size, I won't mind having to put up or use a hoodman loupe as an EVF alternative.
