Lots of people also said, still say, the GXR was an unattractive camera too. But I think looking like it
hasn't been designed is actually a good design look in itself. Sort of like military equipment. I think it looks a lot better than the NEX either with small rangefinder or large SLR lenses. Here's mine with a big fat lens mounted via an adapter just like it would be on a NEX, but big difference don't you think?
The K-01 will surely look and handle better as well when it comes to larger lenses like this.
Originally posted by thebigcat So I'm watching the engadget video and noticed something I hadnt considered before. Since this camera is mirrorless there is nothing protecting the sensor when you change lenses. I believe all sensors have a protective coating anyway and the mirror in a DSLR is not really meant to protect the sensor, but to some extent it does. I will be curious to see if this set up attracts more dust also. Thoughts?
The GXR has a focal plane shutter which you can set with a menu option to start in the closed position or opened. I keep mine in the closed position for exactly the reason to keep dust off the sensor when changing lenses. I assume the K-01 will be similar. You set it to open for cleaning purposes - or displaying at camera show I presume!
