02-18-2012, 05:36 AM   #1
K-01- might this mean a return to proper TTL flash
I was thinking about the expected/hoped-for GXR K mount module, and it occurred to me that the current GXR body is probably not compatible with Pentax flashes. I then discovered that the Ricoh flashes appear to be vanilla TTL. This lead me to realise that the K01 should also be able to work with ordinary TTL.
Is this correct?
Sparkston
02-18-2012, 05:50 AM   #2
Would be a good time to fix up the flash system but I think it may be one body too soon in regards to development time.
flashes, gxr, k-01, k01, mirrorless, pentax k-01, ttl
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 46 11-15-2017 10:05 PM
P-TTL flash - is it necessary ? Squier Pentax DSLR Discussion 35 10-27-2010 12:55 PM
Non-P-TTL AF Flash trailrider Pentax DSLR Discussion 5 07-21-2010 06:04 PM
What is the proper hotshoe adapter to use for a K20D with a Metz 58-AF 1 flash? aweir Flashes, Lighting, and Studio 11 06-25-2009 02:34 PM
All times are GMT -7. The time now is 02:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
