Originally posted by rfortson As a MFT user and a new K-01 owner, I'll chime in and say, yes you can get adapters to add all sorts of lenses to the MFT camera. The adapters are cheap if you want full manual operation, but they're not insignificantly small (not big, but they certainly add to the bulk).
Again, I must correct what are simple factual errors.
The basic mirrorless lens mount adapters do not require "full manual operation" of the camera. There is no need for stop down metering. There is no need for the green button kludge. Metering is automatic and precise.
The only thing you lose is auto-focus which many of us, hobbyists and pros alike, find insufficient in any case. I use manual focus with my 645, with my K20D, and with my PEN cameras. Because only I know where I want to focus, and by the time I tell the AF system I may as well do it myself.
The K-01 advantage over other mirrorless cameras is that you get full AF with K-mount lenses, for those who need it.
Second, the adapters are only as large as they have to be to provide the correct registration distance. This is the same distance already built in to the design of the K-01. On MFT (and likely other mirrorless systems) there is no size penalty for the flexibility of using any mount you want.
If you only want to use K-mount lenses (plus adapted M42 and 645) then the K-01 works a treat. If you want to use any other system lenses, try something else.
Choose the system you prefer for your photographic needs, but please do so without attempting to mislead others trying to make an informed decision.
