Hello All,
I am due for a new camera body. I had been planning to purchase a K-r this year, but the announcement of the K-01 has changed things up a bit.
There are a lot of positives with the K-01, and it would obviously be a huge upgrade from what I am using now (an *istDL). What I am a little concerned about is the lack of a viewfinder. A number of commenters in this forum indicate that the lack of a VF is a deal-breaker! I have never used live-view on a DSLR (other than playing arround with K-r's in camera shops) and do not know if I would really miss a VF.
Has anyone here made the switch from a traditional DSLR to a camera without a VF? Do you miss it, and why? Were there certain times when the lack of a VF was more of an issue than others? Presumably more-so at longer focal lengths? Should the lack of a viewfinder be a deal-breaker if you are not a wildlife photographer?
The vast majority of my photos are made on while travelling on vacation and I like to shoot mostly with wide angle lenses. The most common lenses I use at the momment are a Vivitar 28 mm and the Pentax 10-17mm Fisheye.
Thanks in advance!
Dave
