03-12-2012, 01:47 PM   #1
Pentax K-01 Compact Case
I have a Golla Bag large enough to carry the K-01 with lenses & accessories, I wanted to get a protective case for my K-01, so I can carry it in the automobile console, coat pocket, etc. w/o fear of loosing the 40mm lens cap or causing damage to the camera. I found a very nice, small case at Walmart for $14.00, and thought perhaps there are others who would appreciate such a case for their new Pentax K-01. Case Logic has produced a Compact Camcorder Case (MSEC4) that will fit the K-01 almost perfectly. It comes in Black or in Dark Blue. The case has a molded protective hard shell front & back and a retractable handle system (a shoulder/neck strap is also included). Inside is a tilt-out padded camera cradle (pocket), which makes it very easy to remove or replace the camera. Over-all size is 6.3"x4.75"x3". The DCPI for the MSEC4 Compact Camcorder Case is 0008585419958 (Dark Blue) and 0008585419857 (Black). Incidentally, this case is large enough to carry the K-01 camera/DA40mm XS lens, spare battery, two or three spare memory cards and lens cleaning cloth. Also, you will find that it is less expensive if ordered on-line. Hope this helps someone.
03-12-2012, 03:22 PM   #2
rfortson's Avatar
I found this one from Op/Tech.
https://www.pentaxforums.com/forums/pentax-k-01-forum/178417-what-case-k-01-a.html
03-13-2012, 05:14 PM   #3
Banned
Here are a few shameless plugs and some ideas...
Not sure if Tamrac still makes it, but... The 5220 as a somewhat tight fit for the K-01 with the (new) 40.
But if I might strongly suggest... LowePro makes one of their slip-lock cases that woul easily fit the K-01 and it has a type of water-resistant cover. They also make a waist pack that will hold a few options - also with rain cover.
But what do i know; I consider the LowePro DZ200 or Tamrac 787 to be small bags for me.
03-15-2012, 05:56 PM   #4
This works for me, belt attach walk around.
03-17-2012, 01:43 PM   #5
WWWen, what's the maker/model of the strap? Seems to be a great match for the K-01. A neck strap for it seems too much for me. The bag I presume is a normal P&S bag, correct?
03-17-2012, 02:25 PM   #6
monochrome's Avatar
QuoteOriginally posted by luizpaulo Quote
Some of us use the neck strap as a brace to steady the cam for MF lenses.
03-17-2012, 07:32 PM   #7
OP/TECH USA 1801021 Cam Strap QD- for Compact Cameras and Binoculars -Neoprene (Black)
Available from many stores @ $8.95, won't scratch in my lil baglette.
I also often carry a monopod for steady times and as a walking stick n self defense weapon.
camcorder, camera, k-01, k01, lens, mirrorless, pentax, pentax k-01
Pentax Optio WG-2 - The new waterproof compact leak? Adam Pentax News and Rumors 19 02-07-2012 08:14 PM
A serious compact from Pentax nightjockey Pentax Compact Cameras 11 05-04-2011 06:28 AM
Case/bag recommendation for a WS80 Compact Camera? allyn Pentax Camera and Field Accessories 4 04-20-2010 09:04 PM
What would you like to see in a Pentax compact camera? barondla Pentax Compact Cameras 16 04-15-2010 09:23 PM
Small and compact case/bag for *ist DS + 40mm pancake ankit Pentax Camera and Field Accessories 13 02-17-2008 12:24 PM
All times are GMT -7. The time now is 06:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
