Originally posted by krugorg When I look at the video review here (nice one, btw), it seems like the K-01 focus speed/lock in low light is going to be roughly similar to my Ricoh GXR. It isn't bad, but it is worlds away from the latest, fastest CDAF optimized systems.
So, maybe my expectation is a little lower... I just plan to use the K-01 is situations that are well lit (or plan on using snap focus, etc.) and that do not require a quick AF lock. I will keep using my m4/3 kit for those situations (as others will probably keep using their DSLRs).
Yep - this is the sensible approach. My garage wall is loaded with yard tools. There are 6 different shovels but only 1 spade. I've learned over time which shovel to use for which task and when to choose the spade. I own several rakes with the same learning embedded. I buy the same leather glove every four or five years because they work and they last.
If I choose the tool best suited to the task I am much happier Saturday evening than if I try to force a tool to do a job it wasn't designed for.
I don't think we yet know what job the K-01 was designed for. Until we know that we won't know whether it is the best tool available designed for that job - or just an also-ran. As a group our experiences, praises, criticisms and images will, over time, allow us to use the K-01 when it is appropriate - and choose another tool for those uses where the K-01 doesn't excel.
I'm good with that. I'm not good with dismissing the K-01 altogether after one day of handling because a user had a bad experience with a lens or two in a shooting situation that challenges almost every camera.
