03-14-2012, 01:14 AM   #106
I don't think the K-01 is a flawed concept. The only flaw it has is that an AF system that's just as good as PDAF and can be used with mirrorless cameras hasn't been invented yet, but I'm sure it will be soon enough! It's really hard to get a CDAF system to work just as well with DSLR lenses as other manufacturers' systems do with dedicated mirrorless lenses that have shorter throw.
The Nikon V1/J1 route seems like it would have been ideal here, with a lineup of legacy lenses designed for PDAF.
03-14-2012, 02:29 AM   #107
Clavius's Avatar
I've asked this n00b question a couple of times without responses:
The CDAF is slower because it doesn't know which way to turn to focus... Couldn't the PDAF electronics tell CDAF which way to go then?
03-14-2012, 04:30 AM   #108
QuoteOriginally posted by Clavius Quote
What PDAF electronics are you refering to?
03-14-2012, 04:37 AM   #109
ibkc's Avatar
QuoteOriginally posted by luftfluss Quote
OK, I'll confess...
I have a beige cat. I am one of those (gulp) people who loves to take pics of his kitties. I particularly like to take kitty pics in low-light because the cats' pupils get large, and I think its a cute look. My mother's cat is also beige, although lighter.
Yep, I'm a cat-nerd.
Based on this real-world criteria, and from what I've read here about the K-01, I think that the K-01 is not the camera for me. That doesn't make it a bad camera, though.
Hello fellow beige-cat-owning nerd!
These were taken with the little kit 40mm XS lens in autofocus and although the light isn't particularly low, you'll note in both that there isn't much contrast between cat and surroundings.
However, my 18-55 zoom definitely couldn't handle the same situations in autofocus.
03-14-2012, 05:06 AM   #110
PDAF electronics (in a DSLR) include a separate AF module that needs a way for subject light to get to it. A sub-mirror in front of the image sensor helps take care of that by reflecting some light down into the AF module. The mirrors flip up out of the way in SLR LV, while there are none in a mirrorless camera...only AF sensors there are CDAF built into the image sensor.
03-14-2012, 05:10 AM   #111
Parallax's Avatar
QuoteOriginally posted by Rupert Quote
However, once the hounds are on the trail and running, howling for blood, there is no turning back.
Yep. Remember how it went with some of the K5 issues?
So far they have not been set free on the K-01 but you can see them around here sniffing at the edges.
Regards!
True, and as with the K5, only some of information is coming from people who have actually used a K-01.
03-14-2012, 05:37 AM   #112
Clavius's Avatar
QuoteOriginally posted by jmg257 Quote
That makes sense. Thanks!
It's a pity though, a combo would make the contrast AF both accurate & fast.
03-14-2012, 05:59 AM   #113
GeneV's Avatar
I am just amazed that the first thing someone tries out is shooting a vase in a dim, tungsten-lit living room at night with a kit lens and it is a reason to return a camera.
In all fairness, this is a very common use for a camera. I shoot a lot at parties and concerts, and finding a point to lock focus is always an issue in Tungsten light, especially with ~F4 zooms. It is more so with LV, so I can see why the OP is having an issue.
03-14-2012, 06:01 AM   #114
Banned
QuoteOriginally posted by Tycn Quote
You need a $235 adapter with the V1 /J1 to use Nikon DSLR lenses.
Nikon FT1 Mount Adapter 3613 B&H Photo Video
03-14-2012, 06:14 AM   #115
Docrwm's Avatar
QuoteOriginally posted by jogiba Quote
Now that's funny! I've got a GF2 and picked up a $10 adapter to use my K mount lenses with it.
03-14-2012, 06:14 AM   #116
krebsy75's Avatar
We captured over 200 images in every imaginable lighting condition with the K-01 before using the 18-55 in our living room.
I purchased the K-01 with the understanding that it would offer acceptable auto-focus compatibility with every AF Pentax lens ever made. This proved to not be the case. Perhaps improved firmware will resolve this.
03-14-2012, 06:33 AM   #117
Wheatfield's Avatar
QuoteOriginally posted by mervis Quote
6. I never said Pentax wouldn't let 'a single fault' out the door. I stated (perhaps with some hyperbole) that they would certainly test to make sure the autofocus worked according to the system it chose within the parameters of the body design prior to release. Do you have evidence that they didn't do this?
I'll answer this point, since it is the only one you've made that is anything other than pointless argumentativeness or attempted deflection.
Both the K5 and K-r were released with auto focus that didn't work within it's specified parameters. You should probably go back and read some of the early threads about the K5 where this was much discussed.
03-14-2012, 06:33 AM   #118
krebsy75's Avatar
Hallelujah!
The main issue with the K-01 AF accuracy is that it can sometimes fail to lock focus even when there IS plenty of contrast.
For example, at site one in the photo below:
Pentax K-01 Review - Autofocus Performance - PentaxForums.com
03-14-2012, 06:40 AM   #119
monochrome's Avatar
QuoteOriginally posted by krebsy97 Quote
Early adopters like you and me always suffer from disappointments when we first use our new products. Part of the cause is expecation inflation (we imagine that it will be better than was ever real;ly claimed by the manufacturer) part of the Cause is manufacturer business practice (they use the early adopters as Beta testers; then they use the cash flow from early sales to correct identified issues to attract the early followers) and sometimes part of the cause is plain product design flaws.
The critical business exercise for amanufacturer is to properly weight the 3 issues and make add-on investments accordingly.
03-14-2012, 07:02 AM   #120
krebsy75's Avatar
We actually had really low expectations for the K-01. When we started getting shots with the DA 40mm XS in our house the night the camera came we got really excited. The AF was acceptable and the image quality was K5-like. My wife really enjoyed using the cam and loved how it looked. The camera's clear interface and manual controls also won her over.
Last Sunday we hit the The Turkey Hill Experience | Home Page in Lancaster, Pa. This place is a photographer's dream! Abundant natural light with colorful objects to shoot. Again, with the 40mm XS the K-01 performed admirably. We got lots of keepers and our excitement grew for the camera.
Later that day we hit the playground and attached the 17-70. I bought this lens for my wife last Christmas to use as a walkaround lens. The K-01 had a real difficult time locking focus with this lens even in broad daylight. North of 50-55mm performance was especially dreadful. Having read about the 17-70's reputation for AF fussiness I didn't get too concerned. I was dissapointed but chalked up the issue to the 17-70 having some sort of inherent design flaw that the K-01 couldn't overcome. Keep in mind that we also had problems with the 35mm macro. This was now the second lens in our bag that didn't play nice with the K-01.
My wife was hoping to use the 18-55mm as a crutch lens with the K-01 when travelling light. We captured a few images using this lens in our house to see how it performed. Our experience (with this lens) has been well documented. To make a long story short the K5 in LV mode was able to achieve focus lock more frequently than the K-01.
auto-focus, da, k-01, k01, k5, mirrorless, pentax k-01, test
my most disappointing thing about Pentax slip Pentax DSLR Discussion 16 01-06-2012 10:22 PM
K10D iso 100 noise - bit disappointing Spock Pentax DSLR Discussion 9 01-07-2011 10:22 AM
Pentax disappointing Sensor cleaning. coljung Pentax DSLR Discussion 74 12-02-2010 01:04 PM
Nature A disappointing night... Adam Post Your Photos! 3 11-22-2010 08:00 PM
Nature Discovery Matjazz Post Your Photos! 8 08-08-2010 08:41 PM
All times are GMT -7. The time now is 04:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
