03-14-2012, 06:57 AM   #1
Battery life?
Just read through the review (well done!) and would like to get some type of approximation of battery usage. Given that the LCD is pretty much on all of the time, what are people getting on a charge? I realize that it's difficult to make a strict statement relating charge to number of RAW or JPEG's because that doesn't account for the amount of time that the LCD is on, prior to taking a shot. The review says that battery time is disappointing.
03-14-2012, 08:03 AM   #2
RonHendriks1966's Avatar
QuoteOriginally posted by PeterAM Quote
Well the K-5 gets twice the shots out of this battery and maybe that is why it is disapointing. But compairing to other mirrorless camera's the battery inside the K-01 has plenty of energy.
03-14-2012, 08:05 AM   #3
I think if you dim the LCD or simply just turn it off when you don't take pictures(via "info" button?)
and set the SR to engage just when you start taking pictures, it should last longer.
Yet, sorry didn't directly reply on your question.
03-14-2012, 08:25 AM   #4
I compose mostly by the rear display on my m4/3 bodies and they last in the 300 shot range. My K-01 doesn't arrive until tomorrow, but I anticipated it would have similar battery life, so I ordered the Wasabi batteries:
Amazon.com: Wasabi Power Battery and Charger Kit for Pentax D-LI90, K-5, K-7, 645D: Camera & Photo
I had great luck with these on my Ricoh and Olympus bodies and hope they will work equally well on the K-01.
03-14-2012, 09:08 AM   #5
It does drain a bit too quickly for my liking, but then again, I always have the grip on my K-5, meaning that I pretty much never worry about power.
You can expect a whole day's shooting from the K-01 easily, but it might struggle to do more than that The manual says 500 shots, but you can't really measure that given how much more power the camera uses when standing by compared to DSLRs.
03-14-2012, 09:30 AM   #6
It also depends if the battery has time to regenerate - if I pause for several minutes between shots, most DSLR allow me to take ~1000 pictures.
But if I shoot continuously (e.g. to capture startrails) most batteries are empty after ~200 shots or less - even if I don't use LV.
03-14-2012, 10:14 AM   #7
QuoteOriginally posted by krugorg Quote
Are these the once with a larger charge then the originals? That would come in handy I guess.
03-14-2012, 10:37 AM   #8
QuoteOriginally posted by RonHendriks1966 Quote
Yes, they are rated for 2300mAh versus 1860mAh for the Pentax originals. I have never done a test, but they seem to run as long as my originals for Ricoh and Oly. I think these are above average quality for 3rd party batteries.
03-14-2012, 03:09 PM   #9
WWWench's Avatar
Battery life is not annoying and I always carry extra or 2, as with Flash sticks , just in case.
I use Lenmar No Memory Lithium-Ion Digital Camera Battery for Pentax D-LI90, 7.2v 1730 mAh from Adorama.
03-14-2012, 03:22 PM   #10
frank's Avatar
My K-01 took about 800 shots including around 200 shots for high speed continuoue shots plus a few short videos (mostly because I accidentally pressed on the record button) on one battery, but that's an old battery from K5, probably already seasoned after 1 year plus usage. I think the battery life is pretty decent.
03-14-2012, 03:40 PM   #11
QuoteOriginally posted by frank Quote
Well the type of use does make a huge difference. With my K-5 I can make over 2.000 shots on one battery, with everything off that consumes energy and in Hi-speed modus. I guess that will be the same with K-01: saving energy wll make the battery last longer.
03-14-2012, 06:11 PM   #12
frank's Avatar
Yes, I disable all the sound effect (but can't stop the shutter from making some noise), didn't use flash except a couple of testing shots. The screen will become dimmer after 30sec w/o use, camera goes to sleep after 1min not in use. But I did have some long time shots (up to 10 sec I think), and a lot play w/ the menu settings. Or btw, I took those 800 plus shots over one week span, all in RAW.
03-15-2012, 01:22 AM   #13
Can you turn off instand review in the K-01? I have it off in my K-5, since there is no sense in having that popping up every time. I only check that a few times in the beginning of a shoot and trust my own settings. That would save energy and maybe even make the camera a little more snappier since it goes directly back to liveview.
03-15-2012, 02:04 AM   #14
frank's Avatar
Yes, can. But normally I keep 1s review. Same as my K5 and G3
03-15-2012, 08:05 AM - 1 Like   #15
Nice. Is there also a saving energy way with the backscreen? I asked Ned and he confirmed my assumption that the O-VF1 (from Q) matches nicely with FA 31mm/f1.8 and with that you have a nice combo where you don't need the use of the backscreens liveview output.
battery, charge, k-01, k01, lcd, mirrorless, pentax k-01, review, time
K7 Battery Life jerryleejr Pentax DSLR Discussion 12 10-10-2011 04:01 AM
Battery life of K5 Wheatfield Pentax K-5 27 09-09-2011 03:15 AM
AA battery life jslifoaw Pentax DSLR Discussion 54 06-05-2011 05:26 PM
Battery life for K-x wally1 Troubleshooting and Beginner Help 21 01-25-2011 07:13 AM
Battery Life soppy Pentax K-5 14 12-06-2010 02:02 PM
All times are GMT -7. The time now is 06:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
