03-21-2012, 02:35 PM   #1
Question about K-01.
I just read on "the other site" hands on preview that K-01 cannot do stop down metering and the option is to shoot pre-A lenses wide open only. Not going to buy it, but i did heavily promoted it to someone with lots of old Pentax lenses and told him that it would work just like on my K-5 plus focus peeking. Should i call the guy (hoping he did not order it yet) or it is the hickup of that site?
Thank you in advance.
03-21-2012, 02:44 PM   #2
boriscleto's Avatar
The "other site" is wrong.
03-21-2012, 03:32 PM   #3
Thank you, they changed the article too.
03-21-2012, 09:22 PM   #4
My My -- did that same reviewer mention it's impossible to find Falafel in Israel?
03-21-2012, 11:40 PM   #5
the default step down metering is done by pressing the green button in M mode, and depth of field preview is done by holding down the ev button in M mode
03-22-2012, 09:26 AM   #6
Pentax's method certainly isn't as elegant as the way Nikon (for example) handles it, but it works just fine.
03-28-2012, 10:17 AM   #7
I got mine last week. I found, that it's quite nice. Image quality is OK, but not par with K-5. However I found one HUGE design error: The right hand side rubber lid over the SD-card compartment. What a drag! When holding the camera in the right hand, the rubber cover opens - causing the user to accidently dropping the camera! This is simply not good enough, Mr. Newson. How can you make an obvious huge mistake like this? All these brilliant ideas and efforts - and then this huge blunder!
Didn't you organize user tests? I guess I will have to live with that, but I'm afraid many potential buyers may very well back off, as soon as they realize this big design mistake - BIG MISTAKE, Mr. Newson!
Regards
Jens
03-28-2012, 10:23 AM   #8
QuoteOriginally posted by Photodana Quote
The raw IQ should be identical- we're looking at the same sensor here, and on top of that they've improved the JPEG processing algorithms.
I agree about the rubber cover in that it's tedious to secure, but once it's closed, I didn't have any problems. The major design flaw that I found is that the green button is hard to get to. It should have been on the back of the camera, or at least interchanged with the red button.
03-28-2012, 10:29 AM   #9
monochrome's Avatar
Regards
Jens
You slide the door open by sliding it out as if it is hard metal or plastic, and close the door by sliding it back into the grooves parallel to the body. If you "pry" the door up and press it down it doesn't open easily and doesn't close properly. I don't have any problems at all with the door on my K-01. It closes and stays closed.
03-28-2012, 10:42 AM   #10
Mine must be faulty then - the rubber door is easily opened - by accident - when holding the camera in just one hand - the right one! I don't like the way this door works. I haven't droped it yet, since I know this, but I'm sure I will, some day.
Regards
Jens
03-28-2012, 10:54 AM   #11
monochrome's Avatar
Well I've never held a camera in just one hand so perhaps I haven't experienced whatever causes your door to open.
03-28-2012, 04:06 PM   #12
ibkc's Avatar
Regards
Jens
If the door is opening while you're holding it, then you haven't been closing it correctly. To reiterate what monochrome said: to close the door, slide it into place until it fits into the grooves. Then lightly press down on it to seal it. Do not attempt to close it like a door. Doing so will ensure that it keeps coming open, or catching on your fingers or your strap or whatever.
Once you see how the door is supposed to be closed, you'll get an "Ah-ha!" moment, and then every time after you will be able to close it quickly and easily without a thought. But I absolutely agree that this is a terrible design and not at all intuitive.
k-01, k01, lenses, mirrorless, pentax k-01
A Question for Everyone Fl_Gulfer Photographic Technique 34 11-02-2010 03:33 PM
K7 Question Filson Pentax DSLR Discussion 11 07-02-2010 09:10 PM
SR Question eccs19 Pentax DSLR Discussion 13 05-25-2010 12:14 PM
Question for DA*16-50 henryjing Pentax SLR Lens Discussion 14 04-03-2010 11:39 AM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 06:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
