03-29-2012, 09:31 PM   #1
mervis's Avatar
Another Way To Hold The K-01
Just thought I'd share. My right hand just kind of naturally took up this position when I was holding the K-01 down low as one might use an old Rolleiflex. While the three largest fingers wrap around the grip, the thumb is free to travel over all buttons on the right side, top and back.
I shoot this way sometimes partially for stability (left hand supporting lens, elbows locked against ribcage) and partially for a lower-angled view of things. Also makes one a little less conspicuous if that is desired. Only downside: can't look directly at LCD - more like a 45 degree angle from above. But I see enough to frame the image, trusting the spot AF to lock on to the main subject before my final composition.
Hope this makes some kind of sense.
DMC-LX5  Photo
DMC-LX5  Photo
03-29-2012, 10:07 PM   #2
monochrome's Avatar
Hmmm - worth a try. Imagine that with an articulating LCD!
03-29-2012, 11:14 PM   #3
mervis's Avatar
Yup. My main kvetch about the K-01. File under "No Camera Is Perfect."
hand, k-01, k01, mirrorless, pentax k-01
Cityscape Hold Out tkj365 Photo Critique 2 10-18-2011 09:33 PM
How long will you hold on to your K7? Tony3d Pentax DSLR Discussion 114 11-12-2010 06:26 PM
Cityscape Hold me Closer VaughnA Photo Critique 5 06-18-2010 04:38 AM
Macro Hold on! Iris Post Your Photos! 18 05-24-2010 11:09 AM
About the screws that hold the Pentax K-x together crocowhile Pentax DSLR Discussion 15 04-17-2010 04:09 AM
All times are GMT -7. The time now is 07:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
