04-06-2012, 07:12 AM   #1
Kirill_est's Avatar
K-01 and dust
I own the tiny Q with the newest dust reduction system and have had zero issues so far despite constantly switching between three lenses. I understand that for some strange reason Pentax chose to install the older and less effective dust reduction system in the K-01 and from what I have researched of that older solution implemented on previous Pentax DSLR models, people will get dust on their sensors - and visible on everyday photos - despite being very careful. I owned Sony NEX-3 and I was utterly frustrated by the ineffectiveness of its dust reduction system, ruining my sky shots and such almost every time unless I used the rocket blower at least once after each lens change (always indoors, always having to take white wall shots to check and recheck and re-blow ad nauseam) and sometimes even had to clean the sensor with special swabs. Previously I had owned two m4/3 cameras, Panasonic G1 and Olympus E-P1 with mutliple lenses, never a speck of dust on any of my photographs, so maybe I am spoiled, but the big question remains: what is the experience of K-01 owners? This is the real deal breaker to me, I can just about tolerate the degenerate design.
04-06-2012, 07:18 AM   #2
ibkc's Avatar
No dust here. Not a speck, so far. And I swap out lenses frequently.
04-06-2012, 08:00 AM   #3
monochrome's Avatar
QuoteOriginally posted by Kirill_est Quote
because it fits in the smaller, differently-shaped body
Sensor dust is a fact of life but should not be an every day occurrence. [EDIT:ed out factual error] Though you researched and read posts here and saw images, those were from people who had dust. People who don't have dust never make a post that says, "I don't have dust!!!!" So you could have used might instead of will get dust on the sensor.
There can be no correlation between your experience with your cameras in the past and our experience with our K-01's, nor can there be a correlation between our experience and your experience.
That being said, I haven't had a speck of dust yet and I've changed lenses a lot because I'm experimenting with manual focusing all my lenses and AF testing all my AF lenses. .
04-06-2012, 08:16 AM   #4
Anvh's Avatar
Sensor dust is a fact of life but should not be an every day occurrence. A MILC is not a dSLR. The K-01 shutter is closed at rest, not open, so the sensor is not exposed when you change lenses.
Shutter is also closed at rest with a dslr.
04-06-2012, 08:16 AM   #5
Banned
If a digital camera costs less than two hundred or more than 40k++ it still wll eventualy get something onto it's sensor. Yet one can naturally take precautions to try to limit that type of expose to materials which may find their way onto the sensor.
With the K-01; there are three factors which would help the sensor to hold up better against debris.
1. Even though the sensor is in fact blocked off when changing lens', that... One should still use a bit of caution when changing lens; as some type of debris might find it ways into the chamber between the lens connection and the sensor. Also of note; this is exactly where moisture can in fact completely destroy a camera - if it would somehow manage to get into the chamber. So use caution when there might b any type of water anywhere near the camera - especially when changing lens'.
2. -And here is one which might in fact get quite a bit of criticism. I personally prefer to use Pentax' own lens brand whenever practical - unless they in fact have a type of range that might not be covered. The build quality of the lens structure, and also the physical outteer diameter mounting of the elements is quite critical. I have noticed other third party lens' (for now going unnamed) that might basically allow more "dust or debris" to get through the lens.
3. Operating enviroment of the camera. One is not going to want to operate the K-01 (or most other quality cameras) in an area such as a farm, construction site - or perhaps even a beach area or other area where there is sand.
04-06-2012, 08:42 AM   #6
Kirill_est's Avatar
Well, Q's body is much smaller than K-01's yet the new dust reduction system fits in just fine??
04-06-2012, 08:59 AM   #7
monochrome's Avatar
QuoteOriginally posted by Anvh Quote
Doh.
Adam wrote in his review that the K-01 double cycles its shutter - open-close / open-close. I got confused.
04-06-2012, 09:09 AM   #8
Make sure you turn the camera off when switching lenses, as the sensor is always exposed in live view.
04-06-2012, 09:11 AM   #9
monochrome's Avatar
Here's a thread linking a looong Japanese interview on the K-01 design with Pentax engineers about the interior of the K-01. It explains the rationale for using the old system (magnet location is the key). Post #3 is a Google Translate link to the interview.
Scroll down to this image.
Although I don't know it, I suspect the Q uses a uniquely-designed dust removal mechanism. The APSc mechanism would be overkill for that sensor and I think would itself be physically larger than the Q body. The K-5 SR mechanism is pictured right next to this one in the interview.
04-06-2012, 09:14 AM - 1 Like   #10
rfortson's Avatar
No dust on mine. In fact, I never had problems with my K20D or K5 either, so to me the dust reduction system must be working. I'm not overly concerned about where or how I change lenses, either. I change in the field all the time.
Worry less. Shoot more.
04-06-2012, 09:41 AM   #11
Anvh's Avatar
The sensor has an anti-static coating so if there is dust it's very easy to remove because it doesn't stick.
Don't worry too much about, if you see dust simply clean it.
dust, k-01, k01, lenses, mirrorless, pentax, pentax k-01, reduction, shots, system
Pentax K-7 Dust Alert and Dust Removal Functions brosen Pentax DSLR Discussion 9 02-09-2016 04:43 AM
Please help!! Lens dust or sensor dust? paperbag846 Pentax SLR Lens Discussion 8 11-15-2010 09:25 PM
Where does all the dust go? Aussieflicker Troubleshooting and Beginner Help 6 08-09-2010 10:16 PM
Blowing dust. Will I get more dust inside ? alphalt Pentax DSLR Discussion 7 05-12-2010 10:09 PM
dust on sensor or dust on lens 41ants Troubleshooting and Beginner Help 10 10-08-2009 10:28 AM
All times are GMT -7. The time now is 05:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
