Ron
For the K5 the number when the buffer is full seems to be at 0,8fps so once again where do you get the number of 1,2fps from?
And is that processor limit or SD card limit?
q vs k-01
12,4 mp vs 16mp
jpg - 5,9 fps vs 5,3 fps
RAW = 1,2 fps vs 1 fps
video both 1080p@30fps in h.264
Performance match up pretty well don't you agree?
About the 6fps i mention, look up the Fujitsu Milbeaut M-5 it's in the specs sheet form the manufacture so i ain't lying and yes i can read
Ah but Ron different part of the sensor do different things, file handling is for example not done by the image processor and JPEG conversion is different part as well and probably the filters are done by that as well.
And don't forget the faster SD card bus.
Use a slower card and see if there is still a difference then
As you can see the M4 (prime II) has 5 blocks doing all their own thing.
