05-09-2012, 11:39 PM   #1
Lenses for K-01
If I may ask ones to clarify me the following matters?
1) If the Sigma 18-200mm F3.5-6.3 II DC OS HSM is compatible with K-mouth (without adaptor).
2) Please advise if Pentax 18-200mm available and has better image quality. Which model is it?
3) If we want to compensate the focal length to use Pentax SMC DA 18-135mm F3.5-5.6 ED AL [IF] DC WR. How good is image quality throughout the range comparing with above two lenses.
Thanks in advance.
05-10-2012, 12:22 AM   #2
hcc
hcc's Avatar
QuoteOriginally posted by czadpoom Quote
3) If we want to compensate the focal length to use Pentax SMC DA 18-135mm F3.5-5.6 ED AL [IF] DC WR. How good is image quality throughout the range comparing with above two lenses..
1) You must choose the K-mount version of the Sigma. (K-mount = Pentax mount on K-01)
2) Do you mean the Pentax DA18-250mm? The DA18-250mm is well regarded among the all-around zoom lenses.
3) The DA18-135mm is a WR lens but the K-01 is not a WR lens.
Overall, you are trying to tie up the K-01 with a relatively a large lens. You may wish to consider the lens weight and choose a lighter lens.
Hope that the comment may help.
05-10-2012, 01:17 AM   #3
That's very kind answer. Yes you were right, I had CA-PE-K-01 Pancake 40mm F2.8 along with the camera. I reckon I would love to have the zoom lens and I prefer the Pentax DA18-250mm regarding to the longer all-around zoom lens. But I need to check the weight as you advised for the K-01 is already heavy. Mhmm .. and it is hard to find ones available at conventional photo-shops.
Very much thanks for your swift reply. It's truly fantastic comment.
05-10-2012, 07:48 AM   #4
asahi's Avatar
long lens for K-01?
My 55-300 works just great on my K-01--as some other members have noted about theirs--and it is pretty compact for the range you get. You can hear some work going on there, but the K-01 spins the 55-300 with authority. I was figuring I would use peak focusing out beyond 200mm but even at 300 the auto focus is about as good as that of my K20D--in good light, that is.
Now I am hoping Pentax produces a $250 XS version of the DA Limited 21mm f3.2
05-10-2012, 10:21 AM   #5
monochrome's Avatar
QuoteOriginally posted by asahi Quote
+1 to all of the above - including that the 55~300 requires good light to work well on my dSLR's, too. I bump EvComp at the long end to compensate for the f/5.6 (+270mm, which also brightens the LCD) and if necessary QuickShift touch up the focus, but that is almost never necessary.
Since I don't use the K-01 as a "critical" camera the IQ obtained is so far beyond good enough that I am just delighted with it.
05-10-2012, 10:25 AM   #6
ScooterMaxi Jim's Avatar
Large lens holding method
While I agree that the K-01 works very well with small and light lenses, I do think there is a relatively easy work around for the larger lenses you might want to mount. Use your left hand to support and balance most of the weight of the lens, adding your right hand only for stability and triggering the shutter. It can become second nature pretty quickly. The less than well-endowed grip possibly was designed to encourage this technique (but I might be giving the designer more credit than he deserves).
JNR
05-10-2012, 11:44 AM   #7
monochrome's Avatar
QuoteOriginally posted by ScooterMaxi Jim Quote
JNR
I've said from the beginning (before I actually received mine) that the way to hold this camera is as if it is a film SLR, just as you suggest. Image from my MESuper User Manual.
05-10-2012, 11:49 AM   #8
eddie1960's Avatar
Odds are pretty good that there is a K-01 specific zoom under development as well
the issue with the big super zooms is not just weight, they also don't have the iq of a good prime or smaller zoom. a 2 lens kit with the 18-55 dalII and the DA 55-300 is maybe a better match for the K-01 IMO
better yet is just grab the DA 15,21,70 and the Limited series case which will attach to the strap and you have a high quality compact kit (a little pricier though and still lacking on the longest reach end)
05-10-2012, 12:07 PM   #9
Here's the 18-200 that works with the K-01:
Sigma 18-200mm f/3.5-6.3 II DC HSM Lens for Pentax AF 882109 B&H
Also, we've posted a nice little lens guide here:
Pentax K-01 Lens Guide - Pentax Camera News & Rumors - PentaxForums.com
dc, image, k-01, k01, lenses, mirrorless, pentax, pentax k-01, quality
For Sale - Sold: Tamron 10 - 24mm Ultra Wide Angle Lens f3.5 - f4.5 EdwardConde Sold Items 13 05-16-2012 02:08 PM
Do m42 lenses measure up to todays lenses? Vantage-Point Pentax SLR Lens Discussion 25 05-14-2011 07:51 AM
Huge test on the influence of fungus in lenses (on 9 lenses) CarbonR Photographic Technique 18 03-14-2011 10:34 PM
For Sale - Sold: Yard sale: M lenses, K 300mm, DA 14mm, ME film body, Nikkor lenses and more Nachodog Sold Items 24 12-26-2009 12:03 AM
All times are GMT -7. The time now is 05:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
