07-02-2012, 04:38 PM   #1
Zfinder with K-01
Has anyone used the Zacuto Zfinder Pro with the K-01. Are you able to change the battery with the gorilla plate mounted or must you remove it. Has anyone tried the adhesvie Zfinder mount with K-01? All information appreciated.
07-02-2012, 04:54 PM   #2
Anvh's Avatar
There is no HDMI out during video recording if you're planning to use it for that.
07-02-2012, 04:59 PM   #3
Yes I was aware of that but the Zfinder Pro is an optical device which does not require HDMI.
07-02-2012, 05:56 PM   #4
Anvh's Avatar
Ah i had their EVF in mind, sorry about that.
I sadly cant help you with your question, hopefully someone else can.
There are many other such viewfinders as well, maybe knowing what others use with the K-01 might help you a bit as well.
07-02-2012, 06:04 PM   #5
liukaitc's Avatar
I have a cheap amazon one...works fine with k-5 which has the same LCD as k-01
07-02-2012, 07:21 PM   #6
I got a cheap China one for my K5 and tried it out on a pre-production K-01.
Works well.
All of a sudden, you'd get a super large viewfinder.
Makes MF very easy even w/o the LCD zoom in, if zoom in even at 2x, the keeper rate is fantastic.
The only 2 downsides are how goofy it looks and the need to handle/juggle the LCD Loupe
k-01, k01, mirrorless, pentax k-01, zfinder
All times are GMT -7. The time now is 01:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
