Originally posted by fotogaffer I have both lenses. You can check the excellent review posted on this forum comparing the image quality between these lenses. I don't see much difference in everyday use to justify an "upgrade" to the 40 limited. However, the filter size of the 40 limited is what makes the difference for me, as I can share filters (UV, CP, ND) with my other limiteds with the same 49 mm filter diameter. The 27 mm filter diameter of the 40 XS is an odd size and I'm not keen on acquiring another set of filters in this size if and when available. I find myself using the 40 XS almost like a body cap that doubles for quick snaps, but if I take the K-01 on an outing I am more likely to put on the 40 limited and take along the 21 and 70 DA limiteds and some accessory filters.
The review that just went up was not kind to the 40Ltd with some real issues with sharpness. The 40XS appeared to do better in a number of ways. Do you have the same issues with your pair, or do you think the reviewer got a bum copy of the 40Ltd?
