07-24-2012, 05:55 PM   #16
fotogaffer's Avatar
QuoteOriginally posted by Docrwm Quote
I believe that with the remote ON in the menus the Shake Reduction is set to OFF. So, when you are not using the remote it is wise to turn off the remote setting so your Shake reduction is working.
Yup, just checked and with Remote set to ON the hand on the menu screen is grey with a Red line through it. Definitely off when set to remote.
Good point Docrwm, didn't appreciate that myself until you pointed it out and indeed just checked as well and the SR is off when remote enabled.
Thanks.
07-24-2012, 09:51 PM   #17
ScooterMaxi Jim's Avatar
The logic of this is that an assumption is made that when using the remote, you likely will have the camera on a tripod - and so SR should not be used.
02-25-2013, 08:49 AM   #18
Does the K-01 infra remote have half press for pre-focus?
Thanks.
02-26-2013, 05:53 AM   #19
anthony mazzeri's Avatar
QuoteOriginally posted by Ricky555 Quote
Thanks.
Yes. You have to set it to do so in menu item C11.
02-26-2013, 05:59 AM   #20
Thanks very much!
ir, k-01, k01, mirrorless, pentax k-01
Remote to work Bulb mode????? koukon Pentax K-r 14 08-06-2012 01:01 AM
Pentax Kr remote doesn't work. VE2CJW Troubleshooting and Beginner Help 4 03-09-2012 04:15 PM
Zenit 58mm fits but wont work? emmy957 Troubleshooting and Beginner Help 7 04-13-2011 06:02 AM
Why wont my lens work for my k2000 pgfilms Troubleshooting and Beginner Help 2 11-18-2010 07:46 PM
Does the CS-205 Remote work with the K10D? macdaddy Pentax Camera and Field Accessories 5 02-05-2007 09:04 PM
All times are GMT -7. The time now is 11:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
