Originally posted by Jacquot This must be a really stupid question, but:
With my Mac Air, I put the card in a reader in the USB slot. I open the card file and the update file, and I can copy the firmware file but not paste it onto the card, and it will not drag either. The formatted card just has one directory, so I assume it is the "root."
They say you can download directly into the camera but do not give instructions for that...
David
I have a MacBook Air as well, but I didn't try inserting the SD card directly into the computer's slot. I'm not sure why that wouldn't work. I attached the camera using the supplied USB cable. So the procedure was:
- format the card in the camera (after ensuring you've copied any pictures on it)
- download the mac version of the update (it creates a folder called K01E101M, which includes a file called FWDC214B.BIN)
- attach the camera with the USB cable (it will appear as K-01 on your desktop and in the Finder)
- quit iPhoto if it opens automatically
- drag the file FWDC214B.BIN into the top level of the SD card (not in the DCIM folder)
- eject the camera/SD card from the computer properly
- then follow the procedure in the readme.txt to update the camera
If you have a 16gb card, it is large enough to use. Mine was 8gb. Good luck!
