Originally posted by hcc First do update the firmware:
https://www.pentaxforums.com/forums/pentax-k-01/201724-k-01-firmware-update-1-01-a.html
I have a K-01 and I found the AF is more accurate with the new firmware.
Next charge fully your battery. And get a good quaity card. (There is nothing worth than to loose some shots because of a sub-par card.)
Then setup your camera settings. I like to use center focus point for example.
And then ... enjoy your camera and shoot ....
Comment: the best technique to check the shutter count is to check the EXIF data (eg using Photome) of your files.
Thanks,
Right now the k01's main battery and spare is plugged and is on charge mode so I used my k7's, and yes I do believe that I have a good card (Sandisk extreme 45MB/s*)
Also done with set-up, changed the green-button, but I wish I can change the AE-L or the red button to act like the green, because the green is just way too far.
Spot metering, Focus peaking, center focus, check, check, check, there's so much to change lol.
It took me about 15 - 20 mins to be happy with my set-up. But what I'm really very happy is the high ISO capabilities. I can shoot over 1600 again and get awesome results! The 40xs is sharp wide open, no complains with that (: it also works well with my A and M lenses so I think I'm good so far.
Will do the firmware tomorrow, so far I'm happy with my Tamron 28-75 2.8's performance (AF wise) anyway. (and my K01 won't be needing to use AF so I think it'll be fine )
And yes i made sure it's not yellow.
