10-31-2012, 01:18 AM   #1
=about K-01's stabilizer in video mode=
Hi,
I'm interested in k-01 or k-30 but have some questions about its stabilizer (sr).I've read from some reviews and they said that the stabilizer in video mode is only a Digital stabilzer NOT the sensor shift stabilizer.Is that correct?
Thanks....
10-31-2012, 01:53 AM   #2
AFAIK there is no digital stabilizer in the K-01. SR is active during video if enabled, and can sometimes even be heard.
10-31-2012, 02:09 AM   #3
QuoteOriginally posted by sr196 Quote
Is that correct?
It's fun to take the lens off of your camera while it is operating in live mode and watch the sensor move when SR is on.
10-31-2012, 04:04 AM - 1 Like   #4
This is incorrect. Unlike past pentax camera the k-01 and k-30 use digital stabilization instead of mechanical in video mode. I guess the intention for this was to reduce mechanical noise from the mechanical stabilizer (which is not really an issue in the k-5 by the way). However Pentax have managed to seriously cock-up the implementation.
With digital "movie SR" the sensor readout is cropped so that the image can be tracked.
Also, even if "movie SR" is disabled the additional sensor crop remains - permanently reducing the angle of view of all lenses when used in movie mode.
I think the digital image stabilization that is being used is a hardware implementation in the Fujitsu Milbeaut processor which is used in the K-01 - I think the problem with excessive "jello" is because the Milbeaut stabilization feature is design for global shutter CCD sensors in point and shoot cameras. As such it probably does not accommodate rolling shutter delays which exacerbates the jello effect.
This is poor engineering and it's disappointing to see Pentax let this lazy design out the door.
I am surprised this issue has not had much attention as it could be addressed in the future, if given enough whinging by users.
10-31-2012, 07:57 AM   #5
When you pick up a K-01 and it is off, you can feel the sensor moving inside .. it most definitely has mechanical shake reduction and it does work! The recent firmware update helped with this also. For movies best bet is to turn SR off.
10-31-2012, 09:50 AM   #6
But still,
there is something weird about the stabilization in the K-01 as compared to the K-7 or K-5. To me, the stabilization is unusable in the K-01 in video mode, so I turn it off.... I just have to use a tripod. (and then the video is sweeeeeeet!)
10-31-2012, 06:14 PM   #7
I had to return my K-01 because of excessive jello/rolling shutter. Basically, if SR is on, you see the jello vividly even just holding the camera in hand. If you turn off the SR, the jello goes away but now you have very jumpy video unless you use a tripod. This is just a mess and Pentax is really hurting it's K-01 sales with this issue. The main reason many of us tried the K-01 was for improved video, but the truth is the K-5 has a LOT less rolling shutter and is usable with SR on.
If Pentax fixed this, I would gladly repurchase the K-01, as I really like the yellow version!
10-31-2012, 06:37 PM   #8
My comments were only in relation to SR in video mode. Of course the mechanical system is still there and used for still photography. However unlike past Pentax cameras it is no longer used in video mode.
QuoteOriginally posted by digital029art Quote
05-15-2013, 05:18 PM   #9
QuoteOriginally posted by Ayoh Quote
Are you sure about this? Can you submit some evidence?
PENTAX website implies that the K-01 uses the same sensor-shift
Pentax K-01 - Digital Mirrorless - PENTAX Photo
05-16-2013, 05:00 AM   #10
Ayoh got it right
Sensor shift is for stills only.
Just try it.
Switch it on with no lens attached and set the focal length.
In still capture mode you can watch the sensor jumping around.
Try it in movie mode and there's no sensor movement.
There is some noise, but it doesn't move the sensor.
AB
05-16-2013, 06:43 AM   #11
QuoteOriginally posted by Mutters Quote
Just try it.
AB
Absolutely. If you are shooting still photos and then hit the red button, you actually see your field of view shrink as the digital shake reduction kicks in. It makes your wide angle lenses not quite so wide in video mode, in particular.
05-16-2013, 01:30 PM   #12
There are conflicting assumptions about this. Many review sites and the PENTAX website as shown, say and/or imply that the same SR system is used for video as well as stills. Now it may be modified use owing to the cropped sensor usage for 1080 or 720p footage, (hence the field-of-view change in video mode referred to above) but SS-SR none-the-less.
I've been trying to find indisputable official evidence one way other to satisfy my curiosity, not even the manual is clear enough.
Certainly, digital SR would be a horrible disappointment and would surely degrade the footage when you absolutely wanted to use SR.
05-16-2013, 06:09 PM   #13
Sledger, the absolute irrefutable evidence is watching the sensor NOT moving with SR activated in movie mode.
I don't think it could be any clearer.
The other evidence is the exceptionally offensive rolling shutter affected video footage.
AB
p.s.
What we could hope for is a firmware update that restores sensor movement SR in movie mode, but I think the chance of that is ~zero.
05-16-2013, 06:46 PM   #14
Some pretty trusted review sites who have tested the K-01 tell me different.
Example:
The K-01's video footage displays some of the most severe rolling shutter artefacts that we've seen for a while, and this clip, shot at the long end of an 18-135mm zoom lens, is distinctly wobbly.
The rolling shutter effect seems to be exacerbated, unfortunately, by the K-01's shake reduction function, which if you remember, works by shifting the sensor in response to camera movement to counteract camera shake. Unfortunately, the movement of the sensor, coupled with the severe rolling shutter effect creates distinctly odd-looking footage, which looks rather as if it has been projected onto jello.
Pentax K-01 Review: Digital Photography Review
05-16-2013, 09:35 PM   #15
QuoteOriginally posted by sledger Quote
Example:
Sp you're saying my actual witnessing of the phenomenon isn't valid?
Plus all the others who have discovered the same, don't know either?
I've actually done the test, but that doesn't account for anything, yet a site that does a review without looking deeper will know better?
I'm wondering if you actually own a K-01.
Cheers
AB
k-01, k01, mirrorless, pentax k-01, stabilizer, video
Pentax and Video Mode userage Pentax DSLR Discussion 7 04-29-2012 09:09 AM
K-01 video mode thread jogiba Video and Pentax HDSLRs 16 03-10-2012 06:46 AM
Pentax K-x Video Mode AnnaO Video and Pentax HDSLRs 5 12-12-2011 10:59 PM
K-5 video using tripod. Stabilizer on/off? vanakaru Video and Pentax HDSLRs 3 03-02-2011 10:35 PM
Will using the video-out when in video mode help conserve battery? greenless Pentax DSLR Discussion 2 12-14-2009 02:49 PM
All times are GMT -7. The time now is 10:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
