Originally posted by creampuff Unless one actually uses the K-01, most who have never used it will not be able to shed off any pre-conceived notions of the camera's capabilities (or shortcomings). 12 bit vs 14 bit means very little in practice and irrelevant if one shoots jpegs straight out of the camera. Yes it can be tricky to use it with long lenses and in bright conditions but it really boils down to the photographer's skill or ability to adapt to the camera. The K-01 isn't perfect, what camera is? The only limitation isn't the lack of a viewfinder but the person behind it.
Here's a shot outdoors in bright sun with the K-01 and DA* 300mm handheld... it can be done
Well, I will admit, it is a very very sharp picture.
But for a picture such as this, it tells me more about the sensor's capability and focusing accuracy of DA*300 and K-01 while it tells me nothing about one's skill as a photographer. There is plenty of sunlight too, where one can shoot something like this with rather high shutter speed and wide open aperture. Unfortunately, it tells me nothing about how difficult (or easy) it is to frame a pic with no viewfinder, (or with LCD alone), in that you can sit there and say this was exactly how you wanted to frame it, to the last millimeter, in that the very tip of the fox tail is ever so slightly clipped on purpose just the way you wanted it, and I have absolutely no way of disputing it, because you are the only one that knows.
On the other hand, if you showed me a picture of a flying bird in not so favorable conditions in terms of lighting . . .
